Community
cancel
Showing results for
Search instead for
Did you mean:
JTeo
Intel 320 SSD corrupted.. How to re-format /repair it?
I have a Intel 320 SSD (300GB). it was with Win 7 & PGP FDE.. It got corrupted beyond repair.. went to a few data-recovery services.. all said cannot retrieve data from disk.
I have given up hope in retrieving the data from disk..what I want is to format it and re-use the SSD. is it possible?
In windows.. it "see" the drive as not initialized.. any attempt to initialise it --> time-out error. (semaphore timeout period has expired)
Any tools to do the format?
I tried HDD LLF tool 4.3.. when it try to format the drive.. I get Format error occurred at offset XXXX: 121 - Device not ready (Timeout)
Regards.SSD
Tags (1)
Jose_H_Intel1
You may try with the Intel® SSD Toolbox or with Diskpart (from CMD).
Otherwise you may contact your local Intel® support team.
Intel® Solid-State Drive Toolbox
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455
Intel® Contact Support
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
