cancel
Showing results for
Search instead for
Did you mean:
Intel 330 SSD 180 GB BSOD Win 7 64 bit
Esteemed Contributor III
And again 4 BSOD today with my new SSD...
I think i will return the Stuff to my Hardware Dealer..
Very disappointed about this..
A problem has been detected and Windows has been shut down to prevent damage
to your computer.
The problem seems to be caused by the following file: ntoskrnl.exe
CRITICAL_OBJECT_TERMINATION
If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, followthese steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturerfor any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable BIOS memory options such as caching or shadowing.If you need to use safe mode to remove or disable components, restartyour computer, press F8 to select Advanced Startup Options, and thenselect Safe Mode.
Technical Information:
*** STOP: 0x000000f4 (0x0000000000000003, 0xfffffa8008ffc710, 0xfffffa8008ffc9f0,
0xfffff80002de88b0)
*** ntoskrnl.exe - Address 0xfffff80002ae4c40 base at 0xfffff80002a68000 DateStamp
0x4e02aaa3
i was only writing some Word 2010 docs.. Any Hints setting up my BIOS A 12 on the Dell to prevent this???
Such as SATA / AHCI / C States?!
Thanks !!
0 REPLIES 0
