cancel
Showing results for
Search instead for
Did you mean:
Intel 330 SSD speed Sequential: 350MB/Read and 280MB/Write?
Esteemed Contributor III
I have the Inel 330 SSD with the latest firmware
I ran tests on a SuperMicro Motherboard SATA2 and got speeds of 250MB/s READ and then
installed a HighPoint Pcie2.0 card which is SATA3 and got 350MB/Read, is the fastest it will go?
I like that there was an improvement, but I just thought it would be faster.
I believe I have all the googled' settings properly set, and the latest drivers.
I am running system 32bit windows 8
4GB Ram (2.99 GB Usable)
Motherboard model is: http://www.supermicro.com/products/motherboard/Xeon3000/946/PDSBM-LN2_.cfm Super Micro Computer, Inc. - Products | Motherboards | Pentium® D Boards | PDSBM-LN2+
Rocket 640L is: Marvell 88SE9235 // PCI-Express 2.0 x4
The Rocket is running in the Universal Slot 1 (x4) (x8 physical) PCI-Express Slot via a riser card
[ ] compress this drive to save disk space is not checked
i set page swap size to ZERO
Write Cache is enabled
Anything I am missing to get faster speeds?
I haven't seen the 400MB/s-500MB/s with Sata3 drives ever?
I want to see that happen.
6 REPLIES 6
I got a response back from SuperMicro Support (Motherboard maker)
and they said it was:
"It is PCi-e 1.0"
So the reason I am getting the 350-390MB/s sequential read speeds in
because it's using 2 lanes?
There is no difference in speed between PCIe 1.0 and 1.1. Why SuperMicro said it is PCIe 1.0 I don't know, but it doesn't matter.
Yes, the use of two lanes each for input and output add up to 5Gb/s, the same as the older single PCIe lane Marvell SATA chips, when used on a PCIe 2.0 board.
