Community
cancel
Showing results for
Search instead for
Did you mean:
PONea
Intel 330 Trouble using Acronis XP Alignment Tool (Says to Contact Intel Support)
I installed an Intel 330 SSD in a system using a Gigabyte GA-880GM-D2H running Windows XP x32 using the Gigabyte AHCI driver and when I try to run the XP Alignment tool it does not run and tells me to contact Intel support. I assume this is because it is running AHCI. The Intel SSD Toolbox does see the drive also.
PONea
Solved.....I changed the BIOS to IDE from AHCI and it let me run it....
