Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Intel 510 SSD and secure erase
I'm trying to follow Secure erase instructions (https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase) but I run into a problem I can't really figure out.
I have 2011 iMac, I installed intel 510 ssd and trying to do secure erase (in order to install/reinstall lion). Here's what I do:
1. boot ubuntu (11.04, x86). booting from live CD.
2. run: hdparm -I /dev/sdb. Here's what I get:Security:
Master password revision code = 65534
supported
not enabled
not locked
frozen
not expired: security count
supported: enhanced erase
2min for SECURITY ERASE UNIT. 2min for ENHANCED SECURITY ERASE UNIT.
3. put iMac to sleep and run hdparm again:
Security:
supported
not enabled
not locked
not frozen
And this is where the problems begin...
4.
hdparm --user-master u --security-set-pass passwd /dev/sdb
/dev/sdd:
Issuing SECURITY_SET_PASS command, password="passwd", user=user, mode=high
SECURITY_SET_PASS: input/output error
I tried --user-master m, secure erase with NULL password etc... Nothin works. I _always_ get input/output error regardles of the command...
I'm using latest hdparm (9.37 compiled from sources)
Any idea what is wrong? I don't really want to tear the iMac apart again to disconnect the drive...
Tags (1)
Community Manager
Read: https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase# Known_issues: https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase# Known_issues:
These are almost certainly what you're seeing, or some subset of them.
Community Manager
well... I did follow the steps from wiki exactly... Adn no - I haven't seen any of the issues listed there.
When I switched to ubuntu 10.04 LTS - it worked perfectly! Somethin must have changed between Ubuntu 10.04 and 11.04 (and it's not hdparm - which I compiled from sources both times).
Anyway - for anybody looking to secure erase intel 510 ssd on 2011 imac - just use ubuntu 10.04 LTS.
