Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Intel 520 180GB sudden write speed degradation
I have a brand new SSD Intel 520 180GB.
The sequential write speeds were around 220 MB/s at first (using SATA 2 here).
After just a few benchmarks and Windows 8 installation it's down to 170-180 MB/s.
The read speed is always the same, it's only the write speed that dropped.
I formatted and even completely erased the SSD with diskpart "clean all", but it didn't help. Ran the SSD Toolbox optimizer, scanned the drive.. no errors or anything, I just can't get the write speeds back to normal.
Any ideas?
I can post the pictures from benchmarks if you're interested.
Here's the screenshot from HDTune after the speed drop:
Does this look normal?
I'm using Windows 7 64, Gigabyte P55A-UD4, "native" SATA port (not Marvell).
Community Manager
I installed the benchmark program you used. Read test went fine. When I tried to do a write test the program complained that write tests were disabled because I had active partitions on the disk and they had to be removed before write tests could be done. Removing/deleting partitions on my setup isn't an option because it's the only disc in my computer! I was just curious how my SSD 520 performance compared to your results.
Community Manager
You can try with http://crystalmark.info/download/index-e.html# CrystalDiskMark CrystalDiskMark and http://alex-is.de/PHP/fusion/downloads.php?download_id=9 AS SSD Benchmark, which don't require deleting partitions.
Here are my results before and after:
Some say this is just normal degradation after writing incompressible data. In fact if I try with Atto, which tests with compressible data, it's the same as before.
