cancel
Showing results for
Search instead for
Did you mean:
Intel 520 Series 120G SSD random BSOD's - please help
Esteemed Contributor III
Gday guys,
just wanted to humbly ask for some help. I've recently fitted a new 520 Series SSD into my PC and im getting random BSOD's. I've had 2 today so far after loading a fresh installation of Windows 7 Ultimate 64 early this morning. I wasnt doing anything taxing (just using Firefox and copying files to another PC over ethernet).
My hardware:
Gigabyte P67A-UD7-B3 running 2nd latest BIOS.
8Gb Corsair Vengeance RAM
2x GTX570's in SLI
2Tb WD RE4
1.5Tb WD Green
72Gb WD Raptor.
LG Blu-ray
History:
I had an OCZ Vertex 2 fail completely in my machine last week. No history of any problems before that. I fitted a backup SATA HDD till i received the Intel 520 i planned to replace the Vertex with. No issues with the backup SATA HDD running in IDE mode.
I fitted the intel 520 and initially set it up using IDE. Realising i should have set it to AHCI, i tried the registry tweak trick but it didnt work and wouldnt load windows on reboot anymore. So re-installed Windows fresh using AHCI. Loaded the latest Intel inf drivers, RST drivers and the other mobo drivers from Gigabyte. I also flashed the BIOS to the most recent non-beta version.
First issue was the extremely slow boot times (2 mins to desktop). After i was at desktop, there didnt appear to be any problems except for the first BSOD. Tracked the slow booting problem down to the 1.5Tb WD drive. If i remove it, the boot time is only about 20 secs. Fit the drive, and its back to 2mins. I plan to replace that drive this week but will leave it fitted for now to remove data from it.
Most annoying issue atm is the random BSOD's. The first time it happened, it was too quick and i didnt see the code/ file. No dump file either. I changed windows settings to catch the next one and it happened a few hours later calling a MSRPC.SYS file.
Problem signature:
Problem Event Name: BlueScreen OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 1033
Additional information about the problem:
BCCode: 7a BCP1: FFFFF6FC4000CA68 BCP2: FFFFFFFFC0000056 BCP3: 0000000127165860 BCP4: FFFFF8800194D780 OS Version: 6_1_7600 Service Pack: 0_0 Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\020412-120214-01.dmp C:\Users\cylon2\AppData\Local\Temp\WER-121867-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409 http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Im not sure what to do now. Im just waiting for it to crash again to gather more data i guess. I've read that the Sandforce controllers can cause BSOD issues but i would have thought intel would have ironed those issues by now if theyre using it on their new 520 series. You guys have any thoughts on this?
Apart from swapping the HDD out with another one, is there anything else i can do to narrow down/ force the problem? Maybe its the AHCI playing up? Maybe its not the SSD, but the history of events points towards it. Am tempted to try installing Windows again in IDE mode to see if that changes anything. Is there any special "drive erase" that i should do before reloading windows in IDE mode? Ive just been formatting the drive as per normal.
Would appreciate any advice at all guys. Bit disappointed and have had my head in the pc case for some days now and quite frustrated. Need to get up and running to continue my work. 😐 Thanks for reading so far.
Cheers
Anthony
33 REPLIES 33
GVasi
New Contributor
No one knows smth?
A also tried to set Power Options to High Performance (this definitely disables LPM).
But NO Luck at all.
Also i got BSOD after the intel optimizer runs.
Looks like I'm not the only Intel 520 SSD (120gb) owner suffering with the dreaded 'F4 BSOD'.
The main reason I bought this drive was that Intel's firmware had supposedly fixed this (once common) Sandforce bug, according to anandtech's review. So I was somewhat disturbed to get the F4 crash the first time I left the PC to idle overnight. It has only happened twice since, but I rarely use the PC for more than an hour or two before switching it off.
I'm 99.99% certain it's caused by the SSD, as restarting after the BSOD 'loses' the drive (in BIOS), which returns after a power off/power on cycle - the 'classic' Sandforce symptoms. Plus I've never had any BSOD's before (in over a year of use), except when trying overambitious CPU overclocks (the SSD problems have occurred since I set the CPU back to stock).
I'm running Windows7 x64 Ultimate, a clean install with AHCI enabled. The SSD is connected to the Intel 6gbps (Port0), and is the OS drive, ie not used for cacheing. Intel SSD Toolbox > System Tuner is happy with everything.
My system is :
i5-2500K @ 3.3MHz (stock)
Gigabyte Z68X-UD3H B3 (Rev. 1.0) - F11 BIOS
16gb (4x4) Samsung Green 30nm @ 1866MHz/9-9-9-27-1T
120gb Intel 520 - 400i Firmware, Toolbox 3.0.2, IRST 10.8.0.1003
+WD HDD's, Corsair HX650, MSI 6870 Hawk etc.
Any ideas?? I haven't tried the 'LPM fix', as
1) it's suggested for a SSD with a Marvell controller,
2) I'm wary of touching the registry, and
3) I don't like disabling power management features.
P.S. I get the same Power Cycle Count = Unexpected Power Loss = Unsafe Shutdown Count 'niggle' that has been raised by others. Any news?
P.P.S. @skiman re: poor write speeds in ATTO - If you're using the Foxconn SATA cable supplied with the SSD, try a new cable. The flat cable is folded far too tightly, and caused me a headache until I replaced it with a decent one (that came with the mobo). It gave a very similar ATTO report, where the write speed peaks around QD32/64 and then drops off, never reaching 500MB/s. Intel should know better!
DShar11
New Contributor II
Not sure guys, I have had no bsods with these drives that I am aware of. They have actually been much more resilient than I thought they would be. It seems from your posts that you have done what can be done. I might try to toss the irst drivers and just go with the achi drivers to see if that helps.
"I might try to toss the irst drivers and just go with the achi drivers to see if that helps."
I would have hoped that when getting an Intel SSD to talk to an Intel chipset, the Intel drivers would be good-to-go, rather than generic M$ ones. But then I'm an optimist.
Maybe some of these 'fixes' will help somewhat (AHCI vs IDE, msahci vs IRST, LPM/sleep/hibernate states etc.) but I'd like a definitive answer or firmware fix. OK so I'm not running a multi-national company on this PC, but I regard any stability issues with my primary OS drive as very serious, however occasional and recoverable. That's why I paid 50% more for an Intel product, believing these issues had been resolved (according to anandtech at least) :
http://www.anandtech.com/show/5508/intel-ssd-520-review-cherryville-brings-reliability-to-sandforce http://www.anandtech.com/show/5508/i...y-to-sandforce
"...although Cherryville performs very similarly to other SF-2281 drives, it should be more reliable."
"The BSOD is Back, but Not on Intel" "Switching to Cherryville caused Brian's BSODs to go away." "Whatever Intel has done with the 520's firmware seems to have fixed problems that still remain in the general SF-2281 firmware."
Other sites/reviewers were equally impressed, but this one went into detail of how Intel's validation testing (over 10-12 months) had finally eliminated the Sandforce BSOD. And while the Intel 520 is probably one of the best of the Sandforce drives, there are plenty of unaffected SSD's generally using the Marvell controller (which I won't list on this forum, but include a Motorway joining London and South Wales ).
Overall, my disappointment with this SSD has cancelled out the awe for my i5-2500K, which any SandyBridge owner will tell you is quite considerable.
Just want to clarify. What you are saying is that 520 series has issues with Sandy Bridge? I have an HP Envy 17 with HM67 chipset and am about to drop some $$$ on the Intel 520 / 240 GB SSD. Is this BSOD issue random or P67/H67/HM67 related??/
