Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
Intel 520 Series 120G SSD random BSOD's - please help ...
Community Manager
I installed a 520 series 120gb SSD from Intel and I am now getting the blue screens of death ...
Here is the export from the Intel SSD Toolbox
'ID', 'Description', 'Raw', 'Normalized', 'Threshold', 'Action',
05, Re-allocated Sector Count, 0, 100, 0, Ready for use.,
09, Power-On Hours Count, 895296, 0, 0, Ready for use.,
0C, Power Cycle Count, 42, 100, 0, Ready for use.,
AA, Available Reserved Space, 0, 100, 10, Ready for use.,
AB, Program Fail Count, 0, 100, 0, Ready for use.,
AC, Erase Fail Count, 0, 100, 0, Ready for use.,
AE, Unexpected Power Loss, 40, 100, 0, Ready for use.,
B8, End-to-End Error Detection Count, 0, 100, 90, Ready for use.,
BB, Uncorrectable Error Count, 150729918, 117, 50, Ready for use.,
C0, Unsafe Shutdown Count, 40, 100, 0, Ready for use.,
E1, Host Writes, 150.00 GB, 100, 0, Ready for use.,
E2, Timed Workload, Media Wear, 65535, 100, 0, Ready for use.,
E3, Timed Workload, Host Read/Write Ratio, 74, 100, 0, Ready for use.,
E4, Timed Workload Timer, 65535, 100, 0, Ready for use.,
E8, Available Reserved Space, 0, 100, 10, Ready for use.,
E9, Media Wearout Indicator, 0, 100, 0, Ready for use.,
F1, Total LBAs Written, 150.00 GB, 100, 0, Ready for use.,
F2, Total LBAs Read, 431.59 GB, 100, 0, Ready for use.,
F9, Total NAND Writes, 146, 100, 0, Ready for use.,
'Word', 'Description', 'Value',
0, General Configuration, 0040,
, Bit 15 - ATA Device Identifier, 0,
, Bit 14:8 - Retired, 00,
, Bit 7:6 - Obsolete, 1,
, Bit 5:3 - Retired, 0,
, Bit 2 - Response Incomplete, 0,
, Bit 1 - Retired, 0,
, Bit 0 - Reserved, 0,
1, Obsolete, 3FFF,
2, Specific Configuration, C837,
3, Obsolete, 0010,
4, Retired, 0000,
5, Retired, 0000,
6, Obsolete, 003F,
7-8, Reserved, 00000000,
9, Retired, 0000,
10-19, Serial Number, CVCV2122040X120BGN,
20-21, Reserved, 00000000,
22, Obsolete, 0000,
23-26, Firmware Version, 400i,
27-46, Model Number, INTEL SSDSC2CW120A3,
47, READ/WRITE MULTIPLE Support, 8010,
, Bit 15:8, 80,
, Bit 7:0 - Maximum Sectors, 10,
48, Trusted Computing Feature Set Options, 4000,
, Bit 15 - Must be set to 0, 0,
, Bit 14 - Must be set to 1, 1,
, Bit 13:1 - Reserved, 0000,
, Bit 0 - Trusted Computing Feature Set Supported, 0,
49, Capabilities, 2F00,
, Bit 15:14 - Reserved, 0,
, Bit 13 - Standby Timer Option, 1,
, Bit 12 - Reserved, 0,
, Bit 11 - IORDY Supported, 1,
, Bit 10 - IORDY May Be Disabled, 1,
, Bit 9 - LBA Supported, 1,
, Bit 8 - DMA Supported, 1,
, Bit 7:0 - Retired, 00,
50, Capabilities, 4000,
, Bit 13:2 - Reserved, 0000,
, Bit 1 - Obsolete, 0,
, Bit 0 - Vendor Specific Minimum Standby timer, 0,
51-52, Obsolete, 00000000,
53, Field Validity, 0007,
, Bit 15:8 - Vendor Recommended Free-Fall Control Sensitivity, 00,
, Bit 7:3 - Reserved, 00,
, Bit 2 - Word 88 is Valid, 1,
, Bit 1 - Words 70:64 are Valid, 1,
, Bit 0 - Obsolete, 1,
54-58, Obsolete, 3FFF0010003FFC1000FB,
60-61, Total Number of user addressable sectors, 0DF94BB0,
62, Obsolete, 0000,
63, Multiword DMA Transfer, 0007,
, Bit 15:11 - Reserved, 00,
, Bit 10 - Multiword DMA Mode 2 Selected, 0,
, Bit 9 - Multiword DMA Mode 1 Selected, 0,
, Bit 8 - Multiword DMA Mode 0 Selected, 0,
, Bit 2 - Multiword DMA Mode 2 Supported, 1,
, Bit 1 - Multiword DMA Mode 1 Supported, 1,
, Bit 0 - Multiword DMA Mode 0 Supported, 1,
64, PIO Transfer Modes Supported, 0003,
, Bit 15:2 - Reserved, 0000,
, Bit 1 - PIO Mode 4 Supported, 1,
, Bit 0 - PIO Mode 3 Supported, 1,
65, Minimum Multiword DMA Transfer Cycle Time Per Word (ns), 0078,
66, Device Recommended Multiword DMA Cycle Time (ns), 0078,
67, Minimum PIO Transfer Cycle Time Without IORDY Flow Control (ns), 0078,
68, Minimum PIO Transfer Cycle Time With IORDY Flow Control (ns), 0078,
69, Additional Supported, 4000,
, Bit 15 - CFast Specification Support, 0,
, Bit 14 - Deterministic Read After Trim Supported, 1,
, Bit 13 - Long Physical Sector Alignment Error Reporting Control Supported, 0,
, Bit 12 - DCO IDENTIFY DMA and DCO SET DMA Supported, 0,
, Bit 11 - READ BUFFER DMA Supported, 0,
, Bit 10 - WRITE BUFFER DMA Supported, 0,
, Bit 9 - SET MAX SET PASSWORD DMA and SET MAX UNLOCK DMA Supported, 0,
, Bit 8 - DOWNLOAD MICROCODE DMA Supported, 0,
, Bit 7 - Reserved, 0,
, Bit 6 - Optional ATA Device 28-bit Commands Supported, 0,
, Bit 5 - Read Zero After Trim Supported, 0,
, Bit 4:0 - Reserved, 00,
70-74, Reserved, 000000000000 00000000,
75, Queue Depth, 001F,
, Bit 15:5 - Reserved, 000,
, Bit 4:0 - Maximum Queue Depth - 1, 1F,
76, Serial ATA Capabilities, 4706,
, Bit 15:13 - Reserved, 2,
, Bit 12 - Native Command Queuing Priority Information Support, 0,
, Bit 11 - Unload While NCQ Commands Outstanding Support, 0,
, Bit 10 - Phy Event Counters Support, 1,
, Bit 9 - Receipt of Host-Initiated Interface Power Managament Requests Support, 1,
, Bit 8 - Native Command Queuing Support, 1,
, Bit 7:4 - Reserved, 0,
, Bit 3 - Serial ATA Gen3 Signaling Speed (6.0 Gbps) Support, 0,
, Bit 2 - Serial ATA Gen2 Signaling S...
