Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Intel 520 and BSOD?
Hey guys (=
I've been getting the BSOD (0x0F4) and then the SSD boot drive couldn't be detected while doing the following:
1) Playing Lord of the Rings Online (LOTRO) w/ Hi-Res Texture Pack. I'm also getting the same BSOD even if the game has been closed and using the computer after some time. There's no step-by-step guide to reproduce the BSOD other than letting the game run. The BSOD can happen in a few minutes or in a few hours. Sometimes, the enemy would be named like: "" and a little later the BSOD would appear.
If I restart Windows after playing LOTRO, I would not encounter the BSOD.
Also got a BSOD when ESET AntiVirus 5 was doing a full computer scan while LOTRO was running. It happened after it has completed scanning the SSD and was trying to start scanning the mechanical drive?
2) Copying folders (10GB+) from/to the SSD. However, getting the BSOD in this case is erratic.
3) Playing Far Cry 3 although it only happened after completing the main mission and I decided to do some of the side missions. After getting it twice on different areas, I decided to uninstall the game.
When I get the BSOD and do a warm boot, the system couldn't find the SSD boot drive. Doing a cold boot solves the missing SSD problem. However, sometimes when I immediately do a cold boot the system could remain unstable like if I do a check disk on the SSD, it may or may not complete properly or it could give me an error at the end stating check disk couldn't toggle the run-once setting. Turning the system off for several minutes solves this.
What I've tried:
* Using different driver versions for the Intel Chipset, Intel Rapid Storage Technology (also tried w/o IRST from a fresh Windows install), ASUS Xonar and Nvidia Card.
* Downgraded to a different BIOS version (I had 1805 but now back to 1708)
* Quick reformatted the SSD and reinstalled Windows. Haven't tried secure erasing the SSD.
* Plugging the SSD and HD into different ports and even replaced the SATA cable for the SSD.
* Setting the Windows Power Options to High Performance
* With IRST installed, I applied the LPM fix - but I'm not sure if it's working properly, "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\iaStor" doesn't exist in my registry but I have iaStorA, iaStorF and iaStorV
There was a mention of specifically setting the SSD drive as SSD type in the BIOS (affecting ASRock m/b) However, I couldn't find a similar setting.
There was also a mention of setting the S3 -> S1? Power Management in the BIOS but again, I couldn't find the setting.
I'm not getting a BSOD while playing CivV, Skyrim, a few other games I've played or any other applications I'm using.
My computer can wake itself properly from a sleep state. Although, I just noticed this by chance because I usually don't let my computer enter the 'sleep' state.
System Specs:
Microsoft Windows 7 Ultimate SP1 x64 with all the updates as of this posting
Instead of C:\Users, the Users folder is pointed to the mechanical drive
System RAM: 16331 MB
CPU: Intel Core i7-3770 CPU @ 3.40GHz
Motherboard: ASUS P8Z77M Pro (BIOS Version: 1708)
Graphics Card: NVIDIA GeForce GTX 670 (2047 MB)
SSD: Intel 520 240GB (Firmware Version: 400i)
HD: Western Digital Black 1TB
Sound Card: ASUS Xonar STX
ACHI set in BIOS
Built-in sound card disabled
Intel Virtualization Technlogy enabled
Anyone else have an idea on what I can do (apart from replacing the SSD? ^_^)
Community Manager
Hello, you can try to perform a full diagnostic at the Solid State Drive using the Intel(R) toolbox you can download the toolbox from the following link:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455
if you get an error when you perform the toolbox please contact the Intel(R) technical support for further assistance at the following phone number 916 377 7000 option 7
Community Manager
Thanks MBV2000 (=
I did a full diagnostic scan and I'm getting a BSOD at >20% Then I configured windows to do a diagnostic startup via msconfig and I'm still getting a BSOD at around the same % (The toolbox displayed a red text but didn't get a good look at it before the BSOD)
Unfortunately, I live in the Philippines so can't call the number you posted but I went through the local site and emailed support there.
