Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Intel 520 toolbox see as raid so tool box 3.03 wont work
Hello , have new drive 520 120 gb installed on Biostar TA970XE ,drive is working fine and is single only drive on pc toolbox error sees raid so wont run how do we correct this problem?
Community Manager
so i see this all over as problem and no fix for it? really paid 2x as much for this drive and no service at all when have a problem
Community Manager
What SATA mode and SATA driver are you using on your board? What Intel chipset does it use? This could be a Biostar BIOS issue too.
The Toolbox installation guide notes that this issue exists with some systems, and no workaround exists. You might continue to have this issue with your board.
