cancel
Showing results for
Search instead for
Did you mean:
Intel 530 SSD S.M.A.R.T issue
MRahn
New Contributor II
I have strange issue with my brand new 2.5" Intel 530 SSD 120GB. Every time I start it, in SMART Self-test log appears new test with status:
"Offline - Interrupted (host reset) - Remaining 10%".
If I run the test manually it completes with no errors. And that's really every time. Also SMART info says:
General SMART Values:
Offline data collection status: (0x05) Offline data collection activitwas aborted by an interrupting command from host.
Auto Offline Data Collection: Disabled.
I updated the SSD firmware to latest DC32. Device Model is: INTEL SSDSC2BW120A4. Also tested on different machines and still not found a solution.
Does somebody else has this problem and is there any fix for it?
22 REPLIES 22
Jose_H_Intel1
Valued Contributor II
A full diagnostic scan will indicate if the drive is good or not.
MRahn
New Contributor II
I haven't noticed any problems with the drive till now. Only the auto-generated interrupted self-tests. I will run the full test too and write back but I think it's not normal always to auto-generate these self-test on every start and get interrupt them.
MRahn
New Contributor II
May the auto-generated interrupted offline self-tests appear because my chipset does not support SATA 3 - it's SATA 2?
Here's some SMART Self-test log entries:
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Offline Interrupted (host reset) 10% 10 -
# 2 Offline Interrupted (host reset) 10% 9 -
# 3 Offline Interrupted (host reset) 10% 9 -
# 4 Offline Interrupted (host reset) 10% 9 -
MRahn
New Contributor II
As I promise earlier, I also ran Full Diagnostic Test using Intel SSD Toolbox and it completed successfully. Do you have an idea what is generating these interrupted offline self-tests?
Test # 5 and # 21 were run by me by hand and that's why they are "Completed without error". But all the others are auto-generated and not normal according to me.
SMART Self-test log structure revision number 1
# 5 Offline Completed without error 00% 7 -
# 6 Offline Interrupted (host reset) 10% 7 -
# 7 Offline Interrupted (host reset) 10% 6 -
# 8 Offline Interrupted (host reset) 10% 6 -
# 9 Offline Interrupted (host reset) 10% 6 -
# 10 Offline Interrupted (host reset) 10% 6 -
# 11 Offline Interrupted (host reset) 10% 5 -
# 12 Offline Interrupted (host reset) 10% 4 -
# 13 Offline Interrupted (host reset) 10% 4 -
# 14 Offline Interrupted (host reset) 10% 4 -
# 15 Offline Interrupted (host reset) 10% 4 -
# 16 Offline Interrupted (host reset) 10% 4 -
# 17 Offline Interrupted (host reset) 10% 4 -
# 18 Offline Interrupted (host reset) 10% 4 -
# 19 Offline Interrupted (host reset) 10% 4 -
# 20 Offline Interrupted (host reset) 10% 4 -
# 21 Offline Completed without error 00% 3 -
Jose_H_Intel1
What is the tool you are using to read the logs and run the self-tests?
