Community
cancel
Showing results for
Search instead for
Did you mean:
AStig1
Intel 530 SSD over 4000ms average response time
Hi!
I bought an Intel 530 SSD which I'm now trying to install on my Samsung Laptop (535u3c). The Windows installation is extremely slow, but at least it works.
When I get into Windows I have 100% Disk Usage during the first 30-40 minutes and an average Response Time of about 5000ms. This makes the computer absolutely worthless since I can't use it for the first half an hour. It's a clean install of Windows 8.1 Professional, so shouldn't be anything wrong there.
Can you please help me with this, since I've tried for over a week now to get it to work..
Things I've tried:
Reinstalling Windows
Downloading the toolbox (Intel SSD Tholbox) and done all the tests
Tested using AS SSD Benchmark, (the only test that finished is the Seq. Read and Seq. Write, none of the 3 following tests work at all)
Also tried to clone the things I had on my formed hard drive, but the same problem occured.
Best Regards
Anders Stigsson
Tags (1)
Jose_H_Intel1
I am sorry for your issue, I hope these suggestions help:
Community Manager
Did the AS SSD test show any red text in the upper left hand corner of its display directly above the capacity of the drive? You don't need to run the test itself to check this, just start the AS SSD program.
That would indicate a misaligned SSD, which will have very poor write performance. You would also see if the SATA controller is in AHCI mode, you would see "BAD" in the display.
What is showing the response time as 4000ms average?
