Community
cancel
Showing results for
Search instead for
Did you mean:
sapf
Intel 545s - Значения SMART-атрибутов.
Jump to solution
Подскажите, что значит атрибут "Reported errors count" (на скрине он в самом низу). Перевод говорит, что это "количество зарегистрированных ошибок", но что это за ошибки, из-за чего возникают и можно ли исправить? Raw-значение растёт на единицу через каждые несколько месяцев. Все остальные параметры говорят, что здоровье диска в порядке.
Так же интересует атрибут "Second temperature". Что он означает и для чего нужен, если температуру показывает атрибут "Ariflow temperature"?
Santiago_A_Intel
Hi 3000022803871.5649231140855432E12,
Thank you for your reply to the Intel® SSD.
We have received the SMART data and as we can see, your hardware is working as expected.
Intel performs compatibility tests for several manufacturers; you can find further details in the following Link: http://compatibleproducts.intel.com/ProductDetails?activeModule=Memory%20and%20Storage# your motherboard has not been tested/validated by Intel; this doesn’t means your hardware will not perform as needed.
If there is anything else we can help you with, please let us know.
Have a nice day
Santiago A.
A Contingent Worker at Intel
n_scott_pearson
Super User Retired Employee
First of all, here's a link to a good introduction to S.M.A.R.T. (including its problems): https://en.wikipedia.org/wiki/S.M.A.R.T. As mentioned in this introduction, a problem with the S.M.A.R.T. specification is that, with only a few exceptions, there are no set requirements regarding what attributes are to be provided and how they are used. Implementations differ considerably across the many manufacturers. A common fault in tools that display S.M.A.R.T. attributes is that they do not take into account the differences in attribute usage on a vendor-by-vendor basis. As a result, they often display the wrong title for the attribute and/or misinterpret the raw data provided for this attribute.
Next, let's look at the datasheet for the Intel 545s Series SSDs. I found a copy online here: **** Link Removed **** (this is actually an Intel-confidential document that really shouldn't be there).
From this document, I extracted a summary of the attributes supported:
As you can see from the datasheet (and my summary), some of the attributes listed by your tool are handled incorrectly and others are not even supported by these drives.
Now, to your particular questions,
  1. For this drive series, Intel uses only attribute 190 to provide drive temperatures. I have no idea where this tool came up with this attribute 236, but it isn't supported or exposed by this drive series.
  2. Similarly, attribute 252 is not one exposed by the drive series, so I cannot tell you what it means.
Hope this helps,
Santiago_A_Intel
Thank you for posting in the Intel® SSD community on your request for support on your Intel® SSD 545s Series (512GB, 2.5in SATA 6Gb/s, 3D2, TLC).
For your information, community support is offered only in English language. In case you need to have our responses translated into your language, please use the translation tool provided as part of the community tool.
Please note, we are also using the same translation tool to read your posts; therefore, please be aware, there’s a possibility, the interpretation/translation of the issue, might not be 100% accurate.
In order to provide proper diagnostics for your drive, please proceed downloading the Intel® Solid State Drive Toolbox, please follow this link to get access to the download site: https://downloadcenter.intel.com/download/28808/Intel-Solid-State-Drive-Toolbox?product=35125
For current user’s guide and installation instructions, please follow this link: https://www.intel.com/content/www/us/en/support/articles/000020382/memory-and-storage.html
With Intel® Solid State Drive Toolbox you can see the drive, obtain SMART logs and other information, you will be able to update Firmware or other advanced commands. Please get the SMART logs and post the obtained file in your next post.
We will be looking forward to your reply.
Have a nice day
Santiago A.
Under Contract to Intel Corporation
sapf
posted a file.
Santiago_A_Intel
Have a nice day
Santiago A.
Santiago_A_Intel
Greetings from Intel® SSD support group.
This is a friendly reminder your case remains open, awaiting for your reply.
Have a nice day.
Santiago A.
Santiago_A_Intel
This is to let you know, this case is being closed.
Please feel free to get back to Intel® communities, whenever you might feel necessary.
Have a nice day,
Santiago A.
