Community
cancel
Showing results for
Search instead for
Did you mean:
GWana
Intel 545s and Intel DC S3110
These SSDs seems to have the same characteristics and price. 545s has a controller Silicon Motion SM2259 but which controller is on S3110? Which one is more reliable? What's the difference between 3d2 TLC ( 545s) and 3D nand tlc (s3110)
JosafathB_Intel
Hello GWana, Thank you for contacting Intel® Memory & Storage Support. As we understand you are looking for a comparison between the Intel® SSD DC S3110 Series 128GB, 2.5in SATA 6Gb/s, 3D2, TLC and the Intel® SSD 545s Series 128GB, 2.5in SATA 6Gb/s, 3D2, TLC, if we inferred correctly please visit the following link: https://ark.intel.com/content/www/us/en/ark/compare.html?productIds=125018,129322 To answer your questions: 545s has a controller Silicon Motion SM2259 but which controller is on S3110? That information is not available for the public. Which one is more reliable? Both drives have similar performance and features it depend of the usage that you are going to give to this drive since the Intel® SSD DC S3110 Series is designed for data center/enterprise usage the drive is going to be able to handle bigger workloads for further information please visit the products brief description. https://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/ssd-545s-brief.pdf https://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/ssd-dc-s3100-brief.pdf What's the difference between 3d2 TLC (545s) and 3D nand tlc (s3110) The Intel® SSD DC S3110 Series 128GB, 2.5in SATA 6Gb/s, 3D2, TLC and the Intel® SSD 545s Series 128GB, 2.5in SATA 6Gb/s, 3D2, TLC are listed as 3D2, TLC but in ARK there is a typo on the “Lithography Type” section, we will correct this as soon as possible to avoid future confusions. If you need further assistance please do not hesitate to contact us. Best regards, Josh B. Intel Customer Support Technician Under Contract to Intel Corporation
GWana
Thanks for the answer . Do you know which controller is in Intel DC S3110 ? The controller is the brain of a solid state drive. One of them should be better
GWana
Sorry, I did not read your answer about the controller.
JosafathB_Intel
Hello GWana, Thank you for your reply. We will like to know if you need further assistance or if we can close this case. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
GWana
test.PNGYes, you can close this topic. All versions (128,256,512gb) dc 3110s are better than 545s ( by tests from CrystalDiskMark )
JosafathB_Intel
Hello GWana, Thank you for your reply and thank you for sharing the solution you found with the community. This case is now closed, if you need further assistance please do not hesitate to contact us again. Best regards, Josh B. Intel Customer Support Technician Under Contract to Intel Corporation
