Community
cancel
Showing results for
Search instead for
Did you mean:
HHI
Intel 5500 芯片组 支持pcie硬盘吗?
Intel 5500 芯片组的老服务器,想用最新的Intel P3605 1.6TB 固态硬盘,不知可用否?
Community Manager
Hello NIKIE200807,
According to our translation tools, we understand that you want to know if a server with an Intel® 5500 Chipset can use an Intel® SSD DC P3605 Series.
In order to use this drive, the server/motherboard must be NVMe compatible. The Intel® 5500 Chipset was released back in 2009, way before the implementation of the NVMe standard on Intel® SSD (the first one was released on 2014). Based on this, the server will be unlikely to be compatible with the Intel® SSD DC P3605 Series.
We recommend to contact the server or motherboard manufacturer to confirm if the system is NVMe compliant.
Eugenio F.
