Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
Intel 600p - A failure may be imminent Event 52
KOtte
I have an AsRock Z270M Pro4 board with an Intel 600p 512G NVMe (SSDPEKKW512G7X1) It's a few days old.
In the event log, occasionally an event 52 is logged that says:
The driver has detected that device \Device\Harddisk0\DR0 has predicted that it will fail. Immediately back up your data and replace your hard disk drive. A failure may be imminent.
The Intel Solid-State Drive Toolbox shows the drive health at 100% and the estimated life remaining at 100%. The button to get the SMART details is greyed out but I can get the Drive Details. SMART is enabled in the BIOS. I'll attach the export from the home screen. I also can not use the Intel SSD Optimizer; the buttons are greyed out.
The event log shows this error 5 times since I installed Windows 10. I think it may occur on a cold start, but I'm not entirely sure.
I have the same SSD in another PC with a Z270 board from MSI, and have not received any errors in the event log about it.
Should I be worried?
Kiran
Community Manager
Hello Kiran_Otter,
We understand that your system keeps showing event 52 warning under the event log.
First of all, thanks for the log provided, from the log we can see that the firmware on the drive can be updated, we would like you to please update the https://downloadcenter.intel.com/download/26491/Intel-SSD-Firmware-Update-Tool?product=80097 firmware using this tool.
In case the ISO is not booting up (CD or USB flash drive), please try setting your BIOS to boot mode: Legacy.
Once you have the latest firmware of the drive, could you please monitor how the SSD behaves?
We'll be waiting for your response.
Nestor C
KOtte
Thanks for the reply. After many retries and changing various BIOS settings I finally got the USB firmware update to boot AND where it could see the NVMe SSD. I wish I had taken notes on how I finally got it to work in case it would help someone else.
If I get the error again I'll let you know.
Kiran
Community Manager
Hi Kiran_Otter,
That's good to hear.
About the warnings, we believe that the drive may not be bad or having an issue, this may be related to something else; However, please keep us posted if you see any other warning about it.
Nestor C
KOtte
I'm still getting the same event in the event log. It logged it when I logged in, which could coincide with the loading of the IAStorUI. I have the same SSD in my main PC and don't get this event logged, but I've also discovered the SSD doesn't appear in the IAStorUI utility. Probably because the BIOS isn't set to the Optane/RAID mode. I'm going to experiment with changing that.
Meanwhile I've logged in and out and rebooted with and without the IAStorUI utility enabled at startup and I can't determine what triggers this event to be logged.
Kiran
Community Manager
Hi Kiran_Otter,
Thanks for replying back with the results.
We'd like to know if, besides this event log, is the SSD experiencing any other issues?
Also, it is strange that the MSI* motherboard does not show this event warning and the AsRock* does. By any chance, have you checked with AsRock* about this situation? Especially with NVMe* drives.
Nestor C
KOtte
No, I haven't experienced any problems with the SSD. AsRock does list the 600p as a compatible device. I have not asked them about the event logged. I imagine they would say to contact Intel since it's being identified as possibly failing.
I changed the BIOS on the MSI PC to from AHCI to the RST/RAID mode; now the 600p appears in the Intel SSD Toolbox. I still can't use the optimization option on either PC. I guess it's not supported on the 600p?
If I have time, I could try swapping the SSDs between PCs and see if the event 52 follows the SSD. Might be a couple days before I can do that.
Kiran
Community Manager
Hello Kiran_Otter,
Thanks for confirming the SSD has no problems and for checking with AsRock* as well.
About the Intel® Solid-State Drive Toolbox, this is not compatible to run the optimizer for the 600p series.
The test you mentioned is very important, please try to do the swap and let us know the outcome.
Nestor C
KOtte
I swapped SSDs between PCs, and the AsRock PC still gets the event 52, so it's something to do with that board or the drivers. I'll ask AsRock and see what they say.
Kiran
Community Manager
Hi Kiran_Otter,
Thanks for testing the drives between PCs and confirming this is a situation only with the AsRock* motherboard.
Please post here whenever they provide you with an explanation about it, as this will help some other users as well.
Nestor C
