Community
cancel
Showing results for
Search instead for
Did you mean:
AMacd2
Intel 600p SSD Not Showing During Windows 10 Install
I recently purchased a new laptop (ASUS G752vs) which has Windows 10 installed on the HDD. I bought and added the Intel 512GB 600p SSD to the machine.
I went into disk management and activated the drive and assigned it a letter. I now see the drive in "My PC".
Also if I run diskpart and run a list disk, the disk is there. So far so good.
However, when I launch the windows 10 installer from USB and go to select which drive I want to install windows 10 on, it only shows my HDD.
Is there something that I am currently missing? How do I get the new SSD to appear in the Windows 10 installer list?
Any help is much appreciated.
Cheers
Community Manager
I would try to re-format it first.
AMacd2
Hi, Thanks for the suggestion. I reformatted the drive and no luck. It still works fine within Windows (can move files to and from it) but it doesn't appear during the Windows 10 installer.
Also, I removed the HDD and ran with only my SSD and USB installer plugged in and the installer still couldn't find the SSD.
Anyone seen this issue?
Community Manager
Are you sure that the SSD is fully functional? I would see if it is recognized in another computer.
Community Manager
Hello Hapablap,
We understand that you're looking to install Windows® 10 on your brand new Intel® SSD 600p Series. While the drive is being detected by the OS, the Windows* installer is not showing the drive.
Windows® 10 offers native support for NVMe* SSDs, so there should be no extra steps needed for you to install this OS. However, we have received similar reports from customers working with similar models to yours.
In the majority of these cases, the issue is resolved by updating to the latest BIOS. Others have better luck after disabling the Fast Boot feature from their BIOS until after Windows* has been installed.
- https://www.asus.com/us/Notebooks/ROG-G752VS/HelpDesk_Download/ ASUS* ROG G752VS Downloads.
NOTE: Any links provided for third party tools or sites are offered for your convenience and should not be viewed as an endorsement by Intel® of the content, products, or services offered there.
We hope this information helps. Please let us know if you need further assistance.
Carlos A.
AMacd2
Hi ,thanks for the reply.
I unfortunately do not have another computer with an NVMe M2 PCIE slot to test out this drive. (though it appearing in My PC and being able to format it seems like it is working on some level).
As for the BIOS, I've double checked and I'm running version 306 which is the latest version.
Could there be an issue with the SSD itself? Any suggestions are very welcome.
Edit: Fast boot is also disabled
AMacd2
I noticed my BIOS shows the Intel Rapid Storage Technology as 14.8. Is this perhaps the issue?
I downloaded the 15.2 exe and ran it but the BIOS still shows 14.8. I think I'm missing a step to install the driver.
Community Manager
Hello Hapablap,
From everything that you have reported, you should have no issues installing Windows on this SSD. However, we're aware that some systems do not allow for the OS to be installed on an M.2 drive. It's also possible that you may need to map your M.2 port for NVMe* boot.
In order to confirm this information, we would like to urge you to contact your computer manufacturer support team, to get a more definitive answer on whether or not you will be able to install Windows* on this SSD. Please remember that hardware validation is the responsibility of your computer manufacturer.
- http://www.intel.com/content/www/us/en/support/topics/oems.html Computer Manufacturer Support Websites.
As far as the RST driver goes. To install Windows* on your SSD using the Intel® RST driver, you will first need to make sure that the RST setting is enabled in your BIOS, and the RST driver is saved to your flash drive. Then, on the Windows* installation, once you get to the screen where you need to select where to install the OS, you should have the option to "Load Driver." Here you will simply need to browse to the locating where the driver is saved, after this, you should be able to select the 600p Series.
But again, please check with your computer manufacturer. If there are limitations on where you can install the OS placed by your OEM, you will not be able to despite which method you use.
Carlos A.
AMacd2
The last step that ended up working was switching the SATA mode to AHCI. Afterwards my SSD was noticed and I was able to install Windows 10 successfully.
Thanks for all the help!
Community Manager
Hello Hapablap,
We're glad to hear that you have been able to resolve your issue.
It's odd that your system wasn't set to AHCI by default. If you need any further assistance, please let us know.
Carlos A.
Community Manager
I would also check if your laptop motherboard has an update.
