cancel
Showing results for
Search instead for
Did you mean:
Intel 600p SSD issue
RConr1
New Contributor
I just bought the Intel 512gb 600p and when i install alcohol 120% it asks me to install a driver called SPTD which is located at the following websitehttp://www.duplexsecure.com/downloads/ http://www.duplexsecure.com/downloads/
http://www.duplexsecure.com/downloads/ DuplexSecure - Downloads
The problem is that after i install SPTD for windows 10 i have to reboot and then upon rebooting i get an error called inaccessable_boot_device
I am curious if anyone else is experiencing anything like this?
And if anyone is curious and tries installing SPTD, please make a restore point before you do so as thats the only way to fix the issue
15 REPLIES 15
Esteemed Contributor III
Hello Richardcau,
We are wondering if you have any updates about this situation. We will be waiting for your response.Regards,NC
RConr1
New Contributor
Hello
I got in contact with microsoft and they haven't been able to fix the issue, On the alcohol 120% forums i was told that there is a known windows 10 anniversary bug and also i should ask at duplexsecure.com but there forums don't let you register for some reason so i cannot ask them anything. I installed the new Intel SSD Toolbox and everything shows up and is 100% fine so there probably right about it being microsoft, The only thing i can think of that may help is intel's nvme driver but it hasn't been released for the 600p, will there be a nvme driver for the 600p?
Hi Richardcau,
Thanks for your reply.About the situation your system is having, we do believe the situation may be related with Microsoft*, this because they provide the drive for this drive.Now, about the NVMe* driver, these new series of drives do not require a driver as they will used the "Inbox" driver from the OS. There are no updates on regards us launching a driver for it, we don't think we will be releasing a driver for this SSD, but maybe in a future, it is really hard to tell if this will be happening.Let us know if you require any more assistance from us.Regards,NC
Hi Richardcau,
We would like to know if you require any further assistance or questions about this thread?We will be waiting for your response.Regards,NC
RConr1
New Contributor
Hello
I just recently got a response from Duplex Secure and they emailed me a new version of the SPTD driver which ran fine, after that i installed alcohol 120% and nothing wrong with it so far.
obviously there software was causing the issue and hopefully they release the version i got in the email on there website soon as it has fixed this issue and i think other people should have access to it
Thanks for your help
Richard
