Community
cancel
Showing results for
Search instead for
Did you mean:
AAlex42
Intel 600p series
I want to buy an ssd.
1) IS it an "M" key ssd?
2) I want to put it into PCIE 2.0 slot, if I insert ssd into pci e adapter, will the ssd gain the additional bandwidth from x8 slot or will it be stuck at x4 speeds as the adapter is PCIE3.0x4.
Community Manager
rodriguez3,
We are going to check this for you in order to provide the answer you as soon as possible. Int he mean time, please let us know if you have any other questions or doubts.
Aleki
Community Manager
rodriguez3,
Thank you for your time. we confirm that the Intel® SSD 600p Series is M-key compatible. You can learn more about this drive here http://www.intel.com/content/www/us/en/solid-state-drives/ssd-600p-brief.html Intel® Solid State Drive 600p Series - PRODUCT BRIEF
Regarding your other question, according to this online documentation: http://ark.intel.com/products/94924/Intel-SSD-600p-Series-512GB-M_2-80mm-PCIe-3_0-x4-3D1-TLC Intel® SSD 600p Series Specification the SSD will only use x4
We recommend to contact the motherboard manufacturer for more information about compatibility to make sure you will meet your goal.
Let us know if you have any further questions.
Aleki
Community Manager
rodriguez3,
We haven't heard from you in a while so we would like to know if the explanation we've sent previously helped you to clarify your doubt or if there is anything else we can do to assist you.
Aleki
mMcki1
Problem is:
Besides SSD not being shown in The Bios, It is also not being identified by the OS(Win7). With the following message: Pcie device drivers could not be found.
I run P68 chipset but before saying it is not supported, etc, I can boot from 750ssd.
Community Manager
rodriguez5,
Is there a chance you can try this drive in different computer and see if the same thing happens? If the same situation happens after trying in a different computer, we recommend to contact our support for live attention from one of our technicians in order to obtain additional assistance regarding this particular issue.
Let us know if you find any difficulty contacting our live support either by chat or phone call. Here is the link to our support. http://www.intel.com/content/www/us/en/support/contact-support.html Contact Support
Aleki
Community Manager
rodriguez5,
About a week ago, we have sent you a private message containing a hot fix for the situation reported. In order to make sure you received it, here it is: https://support.microsoft.com/en-us/kb/2990941 Update to add native driver support in NVM Express in Windows 7 and Windows Server 2008 R2
Could you please test it and let us know if it worked for you?
Aleki
Community Manager
rodriguez5,
We haven't heard from you in a while so we would like to know if the information we sent previously helped you to resolve the situation.
Aleki
