Community
cancel
Showing results for
Search instead for
Did you mean:
kRagh
Intel 660p NVME m.2 SSD has variable performance on battery power and charging
Jump to solution
Hi
Just got a brand new asus vivobook 15 X512DA with Ryzen 5 3500U. The laptop came installed with Intel 660p 512GB NVME M.2 SSD.
I noticed that the SSD had varying performance on battery and while plugged in. Using Crystaldiskmark 7-  On battery i got 800/770(R/W) and while plugged in i got
1830/950(R/W). I tried changing power setting to high performance- No difference. All drivers are uptodate. Can anyone please tell me why this is happening?.
 how to make the drive run with the same performance on battery power?
AlHill
I would try a new or known battery, and then contact ASUS for support of their laptop.
Doc
AlHill
Doc
