Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
Intel 660p SSD BSOD "DRIVER_VERIFIER_DMA_VIOLATION" on Win10 latest KB4571756
falken
Hello, while I tested few NVMe SSDs inside TB3 boxes having DCH 987 driver (OWC Express 4M2, UNIBOS Portable SSD x4) with NUC10 kit, ONLY Intel 660p (fw:004C updated from 002C) fails almost always while detection/enabling it. Problem occurs only with latest MS nvmestor driver update in mentioned KB, so simply generic driver changes make him less reliable, but as other disks from different manufacturers are working well, bug is also in your drive. It was 2 days ago reported also to MS over FeedbackHub already. Please fix it working together with MS, tnx.
Labels (2)
BrusC_Intel
Hello, @falken.
Thank you very much for the feedback and all the documentation provided involving this error.
I can certainly submit this information and I'm glad to hear that you already reported this on the MS side as well.
The thread will be closed right now, but feel free to open a new one if necessary, this one will no longer be monitored.
Bruce C.
A Contingent Worker at Intel
BrusC_Intel
Hello, @falken.
Bruce C.
SteinOiestad
FYI
I got the same problem BSOD "VERIFIER_DMA_VIOLATION" as soon as I connected OWC Express 4M2 containing one Intel 660p NVMe. This was on Intel NUC Frost Canyon i7 - BIOS just updated. Windows 10 latest installed. Intel Driver package OK.
As soon as I tried to connect the OWC Express 4M2 Thunderbolt cable the computer rebooted (BSOD as described) immediately. I will try to remove the Intel 660p from the OWC express box (luckily now sw raid yet) and see if the problem persists.
SteinOiestad
FYI - the OWC M42 worked OK when I used only a Crucial 1TB NVMe.
I have both Crucial, Kingston, Samsung and Intel NVMe's, so I will test and see what works and what will not... strange....
falken
Hi, I spent few days with it, it is simply latest stornvme driver with latest 660p firmware only which is failing. 6 other SSDs works there without problem even with new stornvme, but there is definitelly something bad in new driver too. The same happens in single slot UNIBOS PCIe 16x4 enclosure. Posted file "!! -- OWC Express 4M2 TB3, testy.zip" contains timestamped history of AS SSD results on working disks. I also later enabled only "Native OS AHCI" in BIOS and left ASPM disabled there. Since then this OWC  box is working for me fine, having four different SSD inside mounted as stripped NTFS volume "R:". As I will need to process few hundreds of gigybyte ZIP files with my custom software, performance of this all seems to be OK, but now I have here also OWC "Mercury Helios 3" (not new 3S) enclosure and ASUS "Hyper M.2 x16 Card V2", but I expect it will be the same. Thunderbolt3 transparently exposed PCIe just works, but probably as there are potential security issues related to DMA (see thunderspy), new windows "Kernel DMA Protection" feature probably clashes sometimes with drivers/firmware bugs for such externally exposed bus yet. (I had no chance to test new stornvme in any internal M.2 slot. It may be OK too)
SteinOiestad
Very curious - is that the combination - OWC Helios PLUS ASUS Hyper M.2 ?
I first bought the Asus Hyper M.2 card and 4 Intel 660p, but then later understood I need mainboard supporting VROC - so Asus card was just a waste until I buy new desktop/motherboard...
Does this mean that I could put ASUS Hyper M.2 x16 inside Mercury Helios 3(S)" and get four Intel 660p working like that ??
Well, after all drivers/firmware issues have been solved....
Thank you for useful info!
Stein
falken
umm, I am in fact not sure yet, so will test it tomorrow, but VROC seems to be some kind of overkill hardware assisted RAID usable only with intel chipset and SSDs(?):
https://www.intel.com/content/www/us/en/support/articles/000024498/memory-and-storage/ssd-software.h...
as I understood thunderbolt3 for now, it simply exposes PCIe bus over solid and dedicated "usb-c"-like-cable (rather max 0,5m at 40GBs) so I only "expect" now that ASUS card will be working and by default splits wide PCIe x16 bus into four PCIe x4 NVMe M.2 slots, where OS detects separate pci devices, as-is inside Express 4M2 (where his PCIe 4x splits only to PCIe x1 unfortunatelly) and Win10 Disk Manager allow to combine such independent (any manufacturer) disks into single stripped (soft)RAID 0 volume. So now I am curious, really )) ... Express 4M2 works well this way although slightly slower because of 1-lane per disk bottleneck. TB3 40GBs seems to be "quite" good speed for 4 parallel NVMe drives, still not saturating them, thats true.
If you want to try those 4 Intel 660p in Asus card, then I expect uninstalling of KB4571756 with problematic stornvme driver can help as BSOD was caused by that KB only. (dont forget to pause updates, as its pushed again...)
falken
Hi, so its easy, no luck with ASUS, as you were right - its only passive board made solely for Intel VROC and AMD Threadpiper. May be it can work in some MB with PCIE "bifurcation" support in BIOS. Thats probably the reason it was so cheap ... okay
https://www.asus.com/au/support/FAQ/1037507
falken
Well, slow progress ... as NUC10 downloads contains APTIO BIOS TOOLS, and here in manual is something about bifurcation for x8x4x4, then it seems that passive ASUS carrier will work having max 3 SSDs. We will see...
https://www.intel.com/content/dam/support/us/en/documents/intel-nuc/NUC-AptioV-BIOS-Glossary.pdf
falken
Well, no luck with NUC10 bios, next try is this card (heatsinked PCI switch chip):
https://www.supermicro.com/en/products/accessories/addon/AOC-SHG3-4M2P.php
SteinOiestad
Thank you for the tip with AOC-SHG3-4M2P.
Do you think it will work in the OWC Mercury Helio 3S ?
Seems it will be available in Norway in a few weeks, priced at around €120 ex VAT.
https://prisguiden.no/produkt/NTheMTAzMjQyODg
When it comes to Intel 660p firmware upgrade, is the best option to install into a supported notebook. I have severall Dell's that support NVMe ?
Thanks for any advice and your ongoing reporting on progress
