Community
cancel
Showing results for
Search instead for
Did you mean:
SJaso1
Intel 730 480GB SATA Plug Damaged
My Intel 730 480GB SATA Plug is Damaged, can I get warranty coverage from Intel? Thank you
jbenavides
Hello Jason9218,
For warranty issues, we advise you to check the http://www.intel.com/p/en_US/support/contactsupport Contact Support website, here you will find information about the methods available to contact the support center for your region.
The Intel® SSD 730 Series is covered by a five-year limited warranty that can be found at the following location: http://www.intel.com/support/ssdc/hpssd/ssd-730/sb/CS-035332.htm Intel® SSD 730 Series — Warranty for the Intel® Solid-State Drive 730 Series
