Community
cancel
Showing results for
Search instead for
Did you mean:
CPalm5
Intel 750 AIC vs 2.5 in performance in random read workload
Jump to solution
My application is graphics rendering with dozens (up to several hundred) files each in the 10-25MB size range read randomly and repeatedly during a render.
Is there a performance comparison between the AIC (direct PCIE 3.0 x16) and the 2.5 in (PCIE x4/SAS/SATA Express)? Intuition leans me toward the AIC being the better option, but I would like to have that x16 slot available for other things.
Current plans are to use an ASUS z170 Deluxe motherboard with an Intel I6700K processor running windows 10. If I use the 2.5 in version I intend to use the ASUS Hyperkit m.2 adapter to connect the Intel 750.
I would appreciate any input and feedback to help determine which version of the Intel 750 to choose, but particularly performance comparisons under similar workloads.
Thanks!
Tags (1)
jbenavides
Hello PalmerCliff,
Both versions of the Intel® SSD 750 Series are PCIe* Gen3 x4 devices with NVMe interface. The performance specs are the same for both models. The advertised performance is stated in page 8 if the http://www.intel.com/content/www/us/en/solid-state-drives/ssd-750-spec.html Intel® SSD 750 Series Product Specification.
The motherboard you are considering should be able to handle either version of the drive.
Here is a quick description of the 2 form factors, please check the Product Specification document linked above for details:
- The Add-in card is Half-height Half-length and requires a single slot x4 connector, you could use the x16 slots for other devices.
- The 2.5-inch form factor requires the computer to have a U.2 compatible connector like the ASUS Hyperkit* (allowing the PCIe* Gen 3 x4 connection with a M.2 adapter, and SFF-8639 to Mini-SAS HD connector cable)
jbenavides
Hello PalmerCliff,
CPalm5
Thank you Jonathan - that was exactly what I needed.
