Community
cancel
Showing results for
Search instead for
Did you mean:
CKu3
Intel 750 SSD 1.2TB PCI-E firmware upgrade
I'm trying to upgrade my 750 ssd from firmware version 8EV10174 to 8EV101H0 but I did everything I know including using isdct(v3.0.7) , Intel SSD Toolbox(v3.4.7) even Firmware Update Tool(issdfut_2.2.3.iso) but all failed
The following shows isdct logs
C:\isdct>isdct show -intelssd
- Intel SSD 750 Series CVCQ514500XF1P2BGN -
Bootloader : 8B1B0131
DevicePath : \\\\.\\PHYSICALDRIVE0
DeviceStatus : Healthy
Firmware : 8EV10174
FirmwareUpdateAvailable : Please contact your Intel representative about firmware update for this drive.
Index : 0
ModelNumber : INTEL SSDPEDMW012T4P
ProductFamily : Intel SSD 750 Series
SerialNumber : CVCQ514500XF1P2BGN
C:\isdct>isdct load -intelssd 0
WARNING! You have selected to update the drives firmware!
Proceed with the update? (Y|N): y
Updating firmware...
Status : Please contact your Intel representative about firmware update for this drive.
C:\isdct>isdct version
- Version Information -
Name: Intel(R) Data Center Tool
Version: 3.0.7
Description: Interact and configure Intel SSDs.
Toolbox shows the same thing : Please contact your Intel representative...
I also build a linux booter of issdfut_2.2.3.iso and boot successfully but got a meesage
Model Number : Intel SSD 750 Serires 1200GB
Serial Number : CVCQ5xxxxxxxxxx
Firmware 8EV10174
The firmware on this intel SSD is up to date.
but firmware version in issdfut_2.2.3.iso should be 8EV101H0
Motherboard : ASUS Z10PE-D16 WS
OS : Windows 10 Enterprise
Could anyone help me on this?
thanks
Community Manager
Hello clode,
We understand you would like to upgrade the firmware on your Intel® SSD 750 Series, but it is not letting using our tools.
First of all, the Intel® Data Center Tool does not contain the latest version of the firmware, so in this case, you may need to use the other two tools that you have been trying.
Can you please confirm if you installed the NVMe* driver for the SSD? (https://downloadcenter.intel.com/download/27033/NVMe-Drivers-for-Intel-SSDs Download link)
After the driver, the Intel® Solid-State Drive Toolbox should be able to install the latest firmware version on your drive.
In case this does not work, could you please share screenshots of the Intel® Solid-State Drive Toolbox and Firmware update tool?
Nestor C
CKu3
I am very sure I installed latest NVMe Driver 3.1.0.1009
the following are screeshots. FYI
thanks for help.
Community Manager
Hi clode,
In this case, we do suggest to you to try https://downloadcenter.intel.com/download/26167/NVMe-Drivers-for-Intel-SSDs this older version of the NVMe* driver. After that please try the Intel® Solid-State Drive Toolbox or Firmware update tool and let us know.
If possible, could you share a screenshot of the drive's label? (Just hide the serial number and ISN).
Nestor C
CKu3
It's still not working after installing NVMe Driver v1.7.0.1002 (driver version is confirmed on Intel SSD Toolbox System Information page)
And I tried SSD Toolbox and Firmware Update Tool, all messages on above screenshots are not changed.
Is there anything else I could try?
Community Manager
Hello clode,
This is a really strange situation, is it possible for you to perform a secure erase on the drive and reload the operating system?
In case you don't know how to secure erase the drive, you could use Intel® Solid-State Drive Toolbox (Having the SSD connected as a secondary drive) or using https://www.intel.com/content/www/us/en/support/articles/000022179/memory-and-storage.html Diskpart, the commands are in the link, the one you need to use is clean all.
If you can perform this, please share results.
Nestor C
CKu3
Dear Nestor
I performed a secure erase and It's still not working.
But anyway I find that my SDD bootloader version is 8B1B0131 not 8B1B0133.
Is that the problem?
Community Manager
Hi clode,
Could you please check your private messages.
Nestor C
