Community
cancel
Showing results for
Search instead for
Did you mean:
DF2
Intel 750 SSD Failure on System Resume
Hi there, I recently purchased an Intel 750 SSD (2.5 inch drive, model number SSDPE2MW400G4R5) and am having some major issues with getting it to run smoothly. I originally had it as a boot drive for Windows 10 on a newly purchased Gigabyte GA-Z170X-Gaming G1 Motherboard. Everything with the installation went smoothly. The drive was connected to the motherboard via the M.2 to U.2 Add-in-Card. My experience was fine until attempting to resume from the sleep or hibernation state on my computer. Except for a few random instances, the SSD failed to resume the system from sleep and would eventually give up and restart the system altogether. Specifically, my monitors would show nothing and have no display signal, further my mouse and keyboard would quickly disconnect (after waking the computer) and stay disconnected. However, The computer fans would turn on along with all interior lights and stay running. After auto-restarting, I would then be greeted with a blue screen of death with the error message "INACCESSIBLE_BOOT_DEVICE". After the next restart (due to the BSOD), the system would then boot fine, usually taking me to the state where i had originally left the computer when it was slept. Attempting the hibernation state would cause the same error (INACCESSIBLE_BOOT_DEVICE) to appear which would then cause a restart which (after automatic windows repair at the splash screen), would load where i left off at before hibernating the computer. The ensuing hours were then dedicated to trying to find the root cause of the problem. I'll briefly summarize the actions (that I can remember) taken below:
  • Downloaded Intel SSD Toolbox and ensured all drivers were up to date.
  • Uninstalled and reinstalled intel ssd drivers along with various others such as nvidia display drivers.
  • Changed Power State options to high performance, and changed the hard drive turn off option to "never"
  • Downloaded the latest (non-beta) BIOS version for Motherboard. Specific version ID was changed from F2 to F3 (Full hardware info will be provided below)
  • Ran Windows Memory Diagnostic Test, which came back with no errors on the RAM.
  • Ran Full Diagnostic Test on SSD through Intel SSD Toolbox, which came back with no errors.
  • Re-checked for any loose connections within computer case.
  • Uninstalled various non-core programs, and closed non-critical processes before attempting to sleep. Most likely coincidental and non-repeatable, I actually did get the system to resume a few times from the sleep state doing this method. However, after restarting and closing out the same programs and processes, I could not replicate the result. A couple hours of attempts and I gave up on this path.
  • Uninstalled windows 10 altogether and reinstalled Windows 8 cleanly. The issue still persisted in the hibernation and sleep state on windows 8 as well.
At this point, I was out of ideas and decided that the best path forward was to put windows 10 on my SAMSUNG 840 EVO 500 GB to further isolate, confirm, and better diagnose the Intel 750 SSD and the drivers as the underlying issue. As a result, I disconnected all other hard drives/SSD's along with the Intel 750 SSD and installed Windows 10 on the Samsung SSD, I once again attempted the sleep and hibernation states multiple times and over several restarts after installing various programs and drivers. I did not have any issue occur once. The system resumed in roughly 7-10 seconds every time, without a problem.
I now connected all my other storage devices to my PC to once again test for problems. First of all, the Intel 750 SSD was detected and accessible under my devices and drives. I then proceeded to test the sleep state once again without issue on multiple instances. However, the total time to resume from the sleep state increased to roughly 20-30 seconds. Further, the Intel 750 SSD was now no longer detected by windows. Checking Event Viewer lists two relevant entries occurring during system resume.
  1. Error at 12:54:59 AM at Source "stornvme" (event id 11): The driver detected a controller error on \Device\RaidPort2.
  2. Warning at 12:55:04 AM at Source "disk" (event id 157): Disk 4 has been surprise removed.
At this point, I entered into Device Manager and disabled, and then re-enabled the "standard NVM Express Controller". This immediately caused windows to detect the ssd once again and fixed my issue (until the next sleep state is attempted). If anyone could provide any guidance to me on this issue it would be much appreciated. I do know that users have had similar issues with other M.2 SSD's not resuming from sleep state. One solution I've also read about is to disable link power management? However, I don't want to attempt anything else until I perhaps hear from someone with more experience on solving an issue like this. Thanks so much for reading this far, I'll provide a summary of my specs below, but please let me know anything else needed to help aid you all in solving this!
Operating System
Windows 10 Home 64-bit
CPU
Intel Core i3/i5/i7 6xxx @ 3.50GHz 23 °C
Skylake 14nm Technology
RAM
16.0GB
Motherboard
Gigabyte Technology Co., Ltd. Z170X-GamingG1 (U3E1) 28 °C
XB270HU (2560x1440@144Hz)
VG248 (1920x1080@144Hz)
TOSHIBA-TV (1920x1080@60Hz)
NVIDIA GeForce GTX 980 (EVGA)
ForceWare version: 353.62
SLI Enabled
Storage
223GB SanDisk SDSSDHII240G (SSD)
931GB TOSHIBA DT01ACA100 (SATA)
223GB KINGSTON SV300S37A240G (SSD)
372GB NVMe INTEL SSDPE2MW40 (Unknown)
465GB Samsung SSD 840 EVO 500GB (SSD)
Optical Drives
HL-DT-ST BDDVDRW UH12NS30
Audio
Sound Blaster ZxRi
jbenavides
Hello Pc_tuner,
You already tried many troubleshooting steps, like updating BIOS and making sure the connectors are plugged correctly, among other actions.
As you mentioned, the first thing to do is to install thehttps://downloadcenter.intel.com/download/23929/Intel-Solid-State-Drive-Data-Center-Family-for-PCIe-... Intel® Solid-State Drive Data Center Family for PCIe Drivers, the latest version at this time is 1.2.0.1002. Please make sure you are using this version.
Since the Diagnostic test in the toolbox finishes with no errors, this may be due to configuration. Please consider the following:
- When booting from the Intel® SSD 750 Series, the settings required in the Motherboard vary depending on the model and vendor. Please make sure the BIOS Feature: Fast Boot is disabled, and that the OS and Boot features are set correctly. For reference, you can review the following document (this was created for motherboards with the X99 and Z97 chipsets):
http://www.intel.com/support/ssdc/hpssd/sb/CS-035481.htm Intel® High Performance Solid-State Drives — Booting an NVMe* PCI Express* Solid State Drive
- If the issue persists, try disabling Windows* Fast Startup and check if this solves the problem.
DF2
Hi Jonathan, I confirmed I had the latest drivers for the intel 750 ssd via the link you provided and even uninstalled and re-installed them once again (on the intel boot drive) making sure all programs were closed during the installation. As it turns out, I forgot to install the official intel drivers for the ssd on the Samsung boot drive, however they were present on the Windows installation using the Intel SSD as the boot drive. Sorry about that, long night of troubleshooting made me forget that crucial step somehow. However, it would make no difference as this resulted in no change with the Intel SSD failing to be detected while on my current Samsung boot drive. Testing using the intel 750 SSD as the boot drive also showed no difference, with black screens eventually leading to the system restarting once more. Interestingly, the mouse and keyboard were connecting now and are lit up during the resume process but the system still does function.
I then referred to the manual that you linked me and tried to discern the general settings to use on a z170 motherboard by looking at the set up requirements for the x99 and z97 Gigabyte chipset. Through this, I changed "storage boot option control" from "legacy" to "UEFI". To be clear other relevant settings (unchanged) were:
Windows 8 features: Windows 8/10
Other PCI Device ROM priority: UEFI
Fast Boot: Disabled
CSM: Enabled
Attempting the sleep state once again yielded no change in result resulting in the SSD failing and being undetected.
I also disabled Windows Fast Startup in the power options, and then proceeded to sleep my computer. When it powered back on, the Intel SSD was still present!!! Ah Jonathan, I thought you had fixed my problem for good, but i was sadly mistaken. Attempting to navigate into the SSD gave an error message stating that the chosen file path "was not inaccessible. The request failed due to a fatal device hardware error." I then tried disabling and re-enabling the driver which then forced a reboot of the system to re-enable the driver (this had not happened before). Trying the same method once again, this time showed no ssd. I then disabled and re-enabled the driver and it showed up once more and was fully accessible. One last time, I slept the computer again (still with fast startup disabled) and this time showed the intel ssd again. However, it was once again inaccessible and required a reboot to properly re-initialize the driver.
Lastly, their were some new events of note in event Viewer (alongside previously mentioned ones in original post) with several repeating countless times in minutes. These include:
  1. Error at Source "IaNVMe" (event id 11): "The driver detected a controller error on \Device\RaidPort4."
  2. Error at Source "disk" (event id 154): "The IO operation at logical block address 0x476e0 for Disk 4 (PDO name: \Device\00000087) failed due to a hardware error." [MY NOTE: many of these errors occurred rapidly, at various block addresses]
  3. Warning at Source "Nfts" (event id 140): "The system failed to flush data to the transaction log. Corruption may occur in VolumeId: \\?\Volume{7e558c4a-ef96-4b8c-b6a4-5674c4a82e9f}, DeviceName: \Device\HarddiskVolume12. (The request failed due to a fatal device hardware error.)" [occurred numerous times]
  4. Error at "DeviceSetupManager" (event ID 131): "Metadata staging failed, result={E84DF2CA-4ACE-11E5-9BC2-806E6F6E6963} for container '0x80070490'" [occurred numerous times].
  5. Warning at "Kernel-PnP" (event id 219): "The driver \Driver\WudfRd failed to load for the device SWD\WPDBUSENUM\{4d4b97c7-4ad4-11e5-8257-806e6f6e6963}# 0000000000100000." [I believe this occurred when i tried to re-enable the driver myself and it forcing a restart to work]
How should i proceed further with this? Some bios configurations showed CSM being disabled but this was for older chipsets. Is there anyway, you could provide specific settings that you, or Intel recommends I should set with a with my specific z170 motherboard? Again, please let me know if you need further details from me! I'd like to get this sorted as soon as possible.
jbenavides
Hello pc_tuner,
Please use https://downloadcenter.intel.com/download/18455/Intel-Solid-State-Drive-Toolbox Intel® Solid-State Drive Toolbox, current version is 3.3.1, and obtain the SSD logs.
This can be retrieved by clicking the Export button in the bottom–right section of the Toolbox home window.
DF2
Hello Jonathan,
I attached the logs you asked for. Let me know if anything looks out of the ordinary to you!
jbenavides
I checked the log from the SSD, and it looks mostly OK, the drive does not have any SMART errors and it appears to be healthy.
The most important finding is that it shows the drive is working in PCI Gen 1, when it should be Gen 3. This may not be related to the issues resuming from sleep, but is definitely something to look at:
Current PCIe Link Speed 0x1
I was checking the http://download.gigabyte.us/FileList/Manual/mb_manual_ga-z170x-gaming-g1_e.pdf GA-Z170X-Gaming G1* User Manual, and we would recommend you to check with the motherboard vendor to check if they have any additional recommendations to configure the board and prevent this type of issues. Here are some aspects you might want to review with the http://www.intel.com/support/oems.htm Computer Manufacturer Support.
- Which M.2 slot are you using to connect the SSD? Page 36 of the Manual indicates that the M2C_32G M.2 connector is preferred, since the M2B_32G M.2 connector will limit the SSD to x2 speed depending on the configuration.
- Please review the BIOS - M.I.T - Miscellaneous Settings, in page 64 of the guide, it indicates that it is possible to limit the PCIe operation mode.
- Check the information shown in the BIOS - Peripherals - NVME configuration. Let us know if you find anything abnormal, and if possible, provide the information shown in this tab.
DF2
Hi Jonathan, I am using the M2C_32G M.2 Connector on the motherboard and have nothing connected to the SATA 4 and 5 Ports since they do not work with the M.2 slot occupied. The Max link speed set in the BIOS - M.I.T - Miscellaneous Settings is set to the default "AUTO" setting and has not been changed by myself ever.
Interestingly, my motherboard is no longer displaying information under the BIOS - Peripherals - NVME configuration. This is strange as I know it has displayed this information before for me. I tried restarting my computer and it still didn't display anything under this section. However, The Intel SSD is still being picked up by my computer under my SAMSUNG boot drive and is still an accessible and working boot drive by itself.
Another strange thing is that after seeing your post about the Current PCIe Link Speed being 0x1, I exported the SSD results once again and found that it was now 0x3. After sleeping the computer, having the drive not being detected and disabling and re-enabling the driver for the SSD the result now showed that the current PCIe Link Speed as being 0x1 once again. I have posted the two SSD logs relating to this below.
Any idea at all as to what could be causing this and if its related to my issue at all? Thanks so much for looking into this for me!
Further, I have opened a separate thread in regards to this issue on the Gigabyte forums (link is http://forum.giga-byte.co.uk/index.php?topic=16340.0 Intel 750 SSD Crash with Gigabyte GA-Z170X-Gaming G1 Motherboard) . I have also opened a ticket with Gigabyte support but as of yet have heard no response.
jbenavides
Hello Pc_tuner,
The PCIe downshift after sleep may be related to the main issue and we will perform additional research about this. We will provide further updates as soon as we have them.
Please let us know if you receive any news from Gigabyte as well.
DF2
Okay, will do. Thanks for looking into this further.
jbenavides
The information we have suggests that this is due to the design of the motherboard, or BIOS settings. We strongly advise you to check with Gigabyte if the Intel® SSD 750 was validated for your motherboard, and what are the recommendations from their side.
It will be better to wait for the response and recommendations from the motherboard manufacturer. At this point, we can only provide some general recommendations:
- Try booting the system from the Intel® SSD 750 using a light-weight configuration. Leave only the CPU, single memory module, remove additional hard drives, embedded display adapter or single video card, keyboard and mouse connected. PCIe devices, such as video cards, may impact the link speed of PCIe drives. Using a single memory module will help you discard conflicts in the motherboard. Albeit SATA SSD's and other peripherals should not have an influence on the functionality, it will be useful to keep a basic setup, to help you exclude a potential root cause.
- Check you BIOS settings related to PCIe, like Setting up Gen 3 speeds, also, it may have an option for POST delay that will give more time for the SSD to initialize. You might also explore power-related settings (disable power saving features, etc).
DF2
Hi Jonathan, sorry for the delayed response. I tried disconnecting all unnecessary hardware but the issue still persisted. Gigabyte replied back a week after opening the ticket asking the following:
"It appears you have alot of drives installed onto the board, do you only experience this issue with the Intel 750 or with any other sata drives as well?
All other sata drives does not exhibit this issue?
If so, please provide us with more information such as did you applied any type of Windows updates upon completing OS installation and which drivers/software you had applied?"
To tell you the truth, I'm at the end of my rope trying to troubleshoot this one and decided to contact newegg for a refund on the SSD. Sorry you weren't able to fix this one for me, I know you tried your best! Please let me know, if Intel ever determines the potential root cause of this issue. Perhaps, another user will have a similar issue down the line and you'll be able to figure it out through them better.
All the best,
Dean
jbenavides
Hello Dean,
We would like to thank you for your effort in troubleshooting and for all the information you provided. This will help us investigate further about this issue.
MGuy
Hey Jonathan and Dean,
I too am having the exact same issue with my newly installed 750 pcie drive. The drive itself works great, until you do anything related to sleep state. Then it just crashes the PC. I'm running on the x99 platform, and would like some insight if possible. Specs are as follows:
MSI X99 sli plus
i7 5930k
16GB DDR4
Windows 10 64.
-Matt
DF2
Interesting, that's now two other people I have heard from that have my issue. Another user on the gigabyte forum described having the http://forum.giga-byte.co.uk/index.php?topic=16340.0 same issue. I have now returned the SSD, but i'll be monitoring this thread. Best of luck fixing it Matt!
MFrei7
I just want to say that I have the same exact issue as the original poster. On my Gigabyte Z170x-Gaming 5 motherboard, Windows crashes immediately after waking from a sleep state. (Immediate hard freeze, followed by a blue screen of death - BSOD. Reproducible 100% every time.). This occurs *only* if Windows is installed on the Intel 750 PCIe SSD.
On the same exact system, with no hardware changes, installing Windows on another drive (in my case, a SATA Samsung 850 SSD), resolves the problem. The system sleeps and resumes without problem 100% every time. This is true even if the Intel SSD 750 is still installed in the system.
The issue seems to be using the Intel 750 SSD drive as the install drive for Windows. If it is the install drive, Windows will have a BSOD immediately after resuming from sleep. If any other drive is the install drive, the issue is resolved.
Also, I have tried every single troubleshooting step of the original poster. I even went so far as to change various BIOS settings that I thought could potentially be related to the issue with no luck.
MGuy
It's good that people are bringing this to the attention of Intel. I submitted a ticket about this and it has just been escalated to the engineering team. I will share any additional information I get on here of relevance to help you guys out. Cheers
-Omni
DF2
Well I certainly feel your pain! I'm sure Intel will get this sorted eventually
TArnd
I had the same problems on my Asrock z87 Killer (got Bios from Asrock). I thought, my BIOS is the problem, but we are not alone. ;-)
1st, i had a problem, that the drive isn't detected on cold boot. Every reset is working fine, but it wasn't visible (Windows Boot Manager doesn't show up in BIOS as 1st Boot Device). So i think resume have the same problem, no drive found and windows crashes.
After some experiments i just put the drive in the third x4 Slot. Suddenly also the drive is detected just after a cold boot... so perhaps try an other PCIe slot on the mainboard.
For x1 link Speed:
Then i found out, that after a cold boot in the working PCIe Slot the link speed is also just x1, not 4x. This i could fix with just setting in the BIOS Gen3 instead of Auto for the corresponding PCIe slot.
Everything is working now, but the slow boot times are still a pain in the xxx. The Samsung SM951-NVMe drives are out in Germany now. I think i will swap the drive and get some money back. I am curious if it will be working to copy Windows 10 from one drive to another like AHCI in the past.
jbenavides
We are very interested in resolving this condition and would like to get more information about it. Please confirm you have applied the following actions:
1. Install thehttps://downloadcenter.intel.com/download/23929/Intel-Solid-State-Drive-Data-Center-Family-for-PCIe-... Intel® Solid-State Drive Data Center Family for PCIe Drivers, the latest version at this time is 1.2.0.1002.
2. Please make sure the BIOS in you system is up to date. Also, disable the BIOS Feature: Fast Boot, and verify that the OS and Boot features are set correctly. For reference, you can review the following document (this was created for motherboards with the X99 and Z97 chipsets):
3. Try disabling Windows* Fast Startup and check if this solves the problem.
If the issue persists at this point, please use https://downloadcenter.intel.com/download/18455/Intel-Solid-State-Drive-Toolbox Intel® Solid-State Drive Toolbox, current version is 3.3.1, and obtain the SSD logs.
jbenavides
Hello.
We performed additional investigation about this behavior with Asus X99-A and MSI Z170A Gaming M7 motherboards (we do not have your exact motherboard models at hand available for tests); we tried both AIC and 2.5" versions of the 750 with both Intel and inbox NVMe drivers after fresh Windows 10 installation. We were not able to reproduce any of the reported issues during our testing. Considering this, there does not appear to be any general issue with the Intel® SSD 750 series or Intel® NVMe driver, that would cause the 750 not to resume after sleep. Here are some aspects for each of the specific cases reported:
For Pc_tuner and WalGam, the issue appears to be related to particular motherboard design or BIOS implementation of Asus Z170-based boards. While we believe this may not be an issue with the Intel components, we will try our best to get Asus Z170-based motherboard to our labs and do tests on our side to ensure better user experience with 750 series. Once we have any news from our testing, we will update this thread. You might want to contact the http://www.intel.com/support/oems.htm Motherboard OEM support to confirm any settings that may be affecting PCIe* and NVME.
The issue seen by Omni_Gamer seems to be different, based on the symptoms described, but we were not able to reproduce it either. Our advice is to contact MSI for support, we would like to mention that we will continue our tests to try and reproduce this behavior.
KOKOtm, the issue you mentioned is different than the main topic discussed in this thread and does not appear to be related to the 750 SSD, since it was fixed by changing PCIe slot and setting PCIe speed in BIOS. We are glad that everything is running smoothly now.
- Regarding the boot time of the Intel® SSD 750, we are glad to inform that the new firmware contains significant improvements for this. You can check the latest update about 750 boot times in this community thread:
DF2
Thank you for the update Jonathan. Please let me know how any further testing goes. Just for reference, my board is actually a Gigabyte, not an Asus motherboard. I've refunded my SSD now but would not be opposed to purchasing a similar drive once this is sorted. Have a great day and best of luck with everything!
