cancel
Showing results for
Search instead for
Did you mean:
Intel 750 SSD only showing 500MB out of the 400GB it is suppose to have
JHoll9
New Contributor
Hi after installing my SSD it is only showing 500MB max and it is a 400GB SSD
1 ACCEPTED SOLUTION
JHoll9
New Contributor
i figured it out thanks
2 REPLIES 2
jbenavides
Valued Contributor II
Hello Juicec,
We will need some additional information in order to determine the reason why your SSD is showing 500 MB in stead of the 400 GB it should.
- Make sure you are using the https://downloadcenter.intel.com/download/23929/Intel-Solid-State-Drive-Data-Center-Family-for-PCIe-... Intel® Solid-State Drive Data Center Family for PCIe Drivers.
- Where are you seeing this amount of space? If you are using Windows, you should look for it in Computer Management - Disk Management, then confirm that the drive space is shown and properly partitioned. It is possible that there is unused space in your drive.
- Are you using the SSD as boot drive? or is it a data/secondary drive?
Provide additional system details:
- Operating System version
- SSD model (Add in card or 2.5 in)- PC brand and model- Motherboard model- BIOS version
JHoll9
New Contributor
