My windows 10 rebooted yesterday for a Windows update. When I tried to use it afterward my Intel 750 SSD (400GB) is now set as read only. I checked with Diskpart reports "Current Read-only State : Yes" and I can't seem to figure out how to turn that off.
I downloaded the Intel SSD tool but it only shows the drive and only let interact with it or display SMART status, etc.
I can get my files of the drive, but I'm just curious why its gone into this state and if that's a permanent thing or some sort of setting.
Hello Zoid,
Thanks for posting in our forum. We would like to provide some suggestions that may help you with this situation:
-First, try to plug the SSD in a different port and test it
-If that does not work, please try the following:
On the Cmd prompt launch "diskpart.exe"
Run the following commands on the diskpart prompt
LIST DISK
This will list all the disks in your system.
Note down the number of your new SSD, then do the following
SELECT DISK x
Where X is the number of your Intel® SSD 750, then do the following
DETAIL DISK
This will list all the details of the selected disk.
Check if the ReadOnly flag is set to Yes.
Then execute the following command
ATTR DISK CLEAR READONLY
Please let us know if this worked or not, so we can check for further recommendations.
NC
Hi Zoid,
We are following up this thread and we would like to know if you require further assistance or if you have any other question. We will be waiting for your response.
NC
