cancel
Showing results for
Search instead for
Did you mean:
Intel 750 SSD - will a clone copy of the 750 PCIe onto a SATA SSD be able to boot the system?
Esteemed Contributor III
I have been backing up my hard drive by making a 'clone copy' and setting it aside. I've tested those and you can literally plug them in (SATA, or via SATA-to-USB connector) and they boot the system, no different than the original.
Question....if I backed up a 750-series PCIe add-in card onto a regular SATA SSD (I would easily do it via a Apricorn SATA-to-USB connector), would I be able to boot the system with the regular SSD?
1 ACCEPTED SOLUTION
jbenavides
Valued Contributor II
Hello PMM,
Booting from NVMe* drives require specific configuration, like NVMe* drivers, BIOS in uEFI mode and GPT partitions. This configuration may not be compatible once you try to boot from the SATA device, so we cannot guarantee that this would work.
1 REPLY 1
jbenavides
Hello PMM,
