Community
cancel
Showing results for
Search instead for
Did you mean:
PKris6
Intel 750 Series 400GB PCIe NVMe 3.0 SSD slowing down
Hi ,
I am using Intel 750 Series 400GB PCIe NVMe 3.0 SSD. I have noticed that it is not that snappy recently.
I have run the AS SSD Bench mark & I can see the low
Initially this was the test result.
It is getting slower and slower.
I have attached the File from Intel SSD toobox
General Information
Manufacturer : HP
URL : http://www.hp.com http://www.hp.com
Computer : HP Z820 Workstation 103C_53335X G=D (HP 158B)
Version : J63 v03.85
SMBIOS/DMI Version : 2.70
Plug & Play Version : 1.00
Date of Manufacture : 19 November 2014
(EE)PROM Size : 16MB
SCSI General Properties
Controller : 2
Bus : 0
Target ID : 0
Logical Unit No. : 0
General Capabilities
Model : NVMe INTEL SSDPEDMW40
Revision : 0135
Serial Number : VCQC15670*********
Latest Firmware
Version : 8EV1
Date of Manufacture : 12 May 2015
Update URL : http://www.intel.com http://www.intel.com
Translation Mode Disk Geometry
CHS Geometry : 48641 x 255 x 63
Bytes Per Sector : 512bytes
Capacity : 372.61GB
Cache Information
Read Cache : Yes
Write Cache : No
Prefetch Buffer : No
Partitions Information
Partition 1 : GPT EFI system partition 100MB (1MB-101MB)
Partition 2 : GPT Microsoft reserved partition 128MB (101MB-229MB)
Partition 3 : GPT Basic data partition 372.39GB (229MB-372.61GB)
Logical Drives
Logical Drive : C:
Performance Enhancing Tips
Tip 1803 : Disk firmware update available. To update, visit the manufacturer's website.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
jbenavides
Hello randomaccess,
Please use Intel® SSD Toolbox and run the Intel® SSD optimizer function to your drive, then check if this improves the behavior.
Also, check if TRIM is enabled in Windows*. Open a Command Prompt with Administrative privileges and executer the following command:
fsutil behavior query DisableDeleteNotify
If the result is '0', it means that TRIM is enabled.
If the issue persists, please consider the following:
Have you tried running standard maintenance tools on your drive? (Disk cleanup and Error-checking)
Have you noticed any other issues on the system? Application issues, check for viruses, etc.
PKris6
I used the Intel SSD Optimizer, Trim is enabaled. I have done the full virus scan, it was clean.
Windows is unusable , it is freezing all the time, probably waiting to finish writing something.
I cloned the disk on to another SSD which is attached to a areca ARC-1882X Controller Card. I booted from the SATA SSD.
Windows is running smoothly & everything is back to normal.
Here is the benchmark. You can notice Intel 750 is D Drive. You can notice 4K-64Thrd is way too low.
There is definitely something wrong with the Intel 750 PCIE NVME SSD. I am planning to return it if there is no resolution found.
I had faced a similiar problem with Samsung 840 Evo drive for which Samsung released a fix. It was to do more with the read than write.
Here I think it is the write problem.
2015-Aug-09
I deleted everything from the SSD, I used the Intel Optimizer & left it running for 24 hours, but there is no major improvement.
