Community
cancel
Showing results for
Search instead for
Did you mean:
JPhil7
Intel 750 Series OS
Hey,
I am having trouble installing Windows 10 (PRO) on my Intel 750 Series 1.2TB SSD. -- I could install it correctly on my HDD
Sometimes it gets recognized as a boot drive in my Motherboard BIOS, but sometimes it doesn't ( :/ )
Do you guys have any idea?
PC list here: http://pcpartpicker.com/p/WhyK99 http://pcpartpicker.com/p/WhyK99
CPU: Intel Core i7-5960X 3.0GHz 8-Core Processor
CPU Cooler: be quiet! Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler
Motherboard: Asus SABERTOOTH X99 ATX LGA2011-3 Motherboard
Memory: Kingston HyperX Fury Black 32GB (4 x 8GB) DDR4-2666 Memory
Storage: Western Digital BLACK SERIES 4TB 3.5" 7200RPM Internal Hard Drive
Storage: Intel 750 Series 1.2TB (SSDPE2MW012T4R5)
Video Card: EVGA GeForce GTX 980 Ti 6GB Superclocked+ ACX 2.0+ Video Card (2-Way SLI)
Power Supply: SeaSonic 1200W 80+ Platinum Certified Fully-Modular ATX Power Supply
Optical Drive: Asus BW-16D1HT Blu-Ray/DVD/CD Writer
Operating System: Microsoft Windows 10 Pro OEM (64-bit)
Other: ASUS Model Hyper Kit Expansion Card
jbenavides
Hello cortex,
Booting from the Intel® SSD 750 Series is different than booting from SATA drives since the 750 is an NVMe PCIe device, you also need additional configuration if you are using the Asus* Hyperkit.
- We strongly recommend that you contact the http://www.intel.com/support/oems.htm Computer Manufacturer Support and make sure you are using the latest BIOS for your motherboard.
- Please review the following article from Asus for information from them:
*NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
http://rog.asus.com/415802015/asus-gaming-motherboards/intel-750-2-5-inch-ssd-with-nvme-and-asus-hyp... http://rog.asus.com/415802015/asus-gaming-motherboards/intel-750-2-5-inch-ssd-with-nvme-and-asus-hyp...
- Here is a document that has some examples of the BIOS configuration required to Boot from the 750 using different motherboards:
http://www.intel.com/support/ssdc/hpssd/sb/CS-035481.htm Intel® High Performance Solid-State Drives — Booting an NVMe* PCI Express* Solid State Drive
