Community
cancel
Showing results for
Search instead for
Did you mean:
CNeve2
Intel 750 Series PCIe or Regular SSD in Raid0-The best performance or an Issue?
Hello!!
I work with several photos in Raw format (D800) using Lightroom. When i put the photos in Intel SSD and begin work edition, the Lightroom is much more slow to render the photos. When i put the photos in a simply Raid 0 SSD Kingston, the lightroom works extremely fast rendering the photos. My base set up is i7 6950x, Rampage V Extreme, Gskill Trident Z 3000 (4x8GB), Asus 1080 Strix. The Windows 10 is allocated in a Samsung 950 Pro. Anybody knows a solution? The Intel 750 has the latest firmware, is connected in the 3th PCI slot and the Cristal Disk Shows: 2334/998 Read an Write to Intel and just 995/336 to Raid 0... Thanks a lot
Community Manager
Cnevers,
Unfortunately, we can not refer to third-party tool performance on third-party SSDs. However, you can check if you are running the latest NVMe* drivers for the Intel® SSD 750 Series. For your convenience, here is the link to it: https://downloadcenter.intel.com/download/26167/Intel-SSD-Data-Center-Family-for-NVMe-Drivers?v=t Intel® SSD Data Center Family for NVMe* Drivers
If the Intel® SSD 750 Series presents any performance issue, please send us the SSD export logs obtained through the https://downloadcenter.intel.com/download/26085/Intel-Solid-State-Drive-Toolbox Intel® Solid State Drive Toolbox
Aleki
Community Manager
Cnevers,
We haven't heard from you in a while so we would like to know if you still need our assistance.
best regards,
Aleki
