Community
cancel
Showing results for
Search instead for
Did you mean:
SChan70
Intel 750 not showing up in ESXi 5.5
Judging from another question, I guess it is possible. I have 1.0e.2 installed:
~ # vmkload_mod -s intel-nvme
vmkload_mod module information
input file: /usr/lib/vmware/vmkmod/intel-nvme
Version: 1.0e.2.0-1OEM.550.0.0.1391871
License: BSD
Required name-spaces:
com.vmware.vmkapi# v2_2_0_0
Parameters:
On this box, I have two SATA SSDs, a Intel 3700 and this drive. The 3700 shows up fine.
~ # esxcli storage core device list
t10.NVMe____INTEL_SSDPEDMD400G4_CVFT4474004C400BGN__00000001
Display Name: Local NVMe Disk (t10.NVMe____INTEL_SSDPEDMD400G4_CVFT4474004C400BGN__00000001)
Has Settable Display Name: true
Device Type: Direct-Access
Multipath Plugin: NMP
Devfs Path: /vmfs/devices/disks/t10.NVMe____INTEL_SSDPEDMD400G4_CVFT4474004C400BGN__00000001
Vendor: NVMe
Model: INTEL SSDPEDMD40
Revision: 0110
SCSI Level: 6
Is Pseudo: false
Status: on
Is RDM Capable: false
Is Local: true
Is Removable: false
Is SSD: true
Is Offline: false
Is Perennially Reserved: false
Queue Full Sample Size: 0
Queue Full Threshold: 0
Thin Provisioning Status: unknown
Attached Filters:
VAAI Status: unknown
Other UIDs: vml.010000000043564654343437343030344334303042474e2020494e54454c20
Is Local SAS Device: false
Is USB: false
Is Boot USB Device: false
No of outstanding IOs with competing worlds: 32
750 is there:
\==+PCI Device :
|----Segment.........................................0x0000
|----Bus.............................................0x81
|----Slot............................................0x00
|----Function........................................0x00
|----Runtime Owner...................................vmkernel
|----Has Configured Owner............................false
|----Configured Owner................................
|----Vendor Id.......................................0x8086
|----Device Id.......................................0x0953
|----Sub-Vendor Id...................................0x8086
|----Sub-Device Id...................................0x370d
|----Vendor Name.....................................Intel Corporation
|----Device Name.....................................NVM-Express PCIe SSD
|----Device Class....................................264
|----Device Class Name...............................Non-Volatile memory controller
|----PIC Line........................................11
|----Old IRQ.........................................11
|----Vector..........................................57
|----PCI Pin.........................................0
|----Spawned Bus.....................................0
|----Flags...........................................513
<p style="font-size: 18p...
Community Manager
Please use the Intel NVMe drivers for VMware*. https://downloadcenter.intel.com/download/23929/Intel-Solid-State-Drive-Data-Center-Family-for-NVMe-... Download Intel® Solid-State Drive Data Center Family for NVMe Drivers\
Community Manager
Or now I see you have an Intel SSD DC P3700 series showing fine. This is what we know
Which driver are you using...
SChan70
Thanks for that link. I tried with both Intel drivers '1.0e.2.0-1OEM.550.0.0.1391871' and VMware driver '1.0e.0.30-1vmw.550.0.0.1391871'. Both see the DC P3700 and both do not see the 750. I saw another commenter ask about delete support for 750 under ESXi and was hoping that meant these worked with ESXi. It is not in the HCL list though I've seen many drives not on that list work just fine. Thanks Warren
SChan70
Tried moving the 750 into its own box without any other Intel NVMe drives; still no dice.
000:081:00.0
Address: 000:081:00.0
Segment: 0x0000
Bus: 0x81
Slot: 0x00
Function: 0x00
VMkernel Name: vmhba2
Vendor Name: Intel Corporation
Device Name: Non-Volatile memory controller
Configured Owner: Unknown
Current Owner: VMkernel
Vendor ID: 0x8086
Device ID: 0x0953
SubVendor ID: 0x8086
SubDevice ID: 0x370d
Device Class: 0x0108
Device Class Name: Non-Volatile memory controller
Programming Interface: 0x02
Revision ID: 0x01
Interrupt Line: 0x0b
IRQ: 11
Interrupt Vector: 0x39
PCI Pin: 0xd0
Spawned Bus: 0x00
Flags: 0x0201
Module ID: 18
Module Name: nvme
Chassis: 0
Physical Slot: 1
Slot Description: Chassis slot 1.00
Passthru Capable: true
Parent Device: PCI 0:128:2:0
Dependent Device: PCI 0:129:0:0
Reset Method: Function reset
FPT Sharable: true
Tried with Intel as well as VMware drivers. Not sure how it worked for the other person :-(
SChan70
Doesn't work with ESX 6.0 either both with the builtin driver and Intel
License: BSD
Parameters:
Built in:
~ # vmkload_mod -s nvme
input file: /usr/lib/vmware/vmkmod/nvme
Version: 1.0e.0.35-1vmw.600.1.17.3029758
Build Type: release
License: BSD
com.vmware.vmkapi# v2_3_0_0
Parameters:
nvme_compl_worlds_num: int
Total number of NVMe completion worlds/queues.
max_namespaces: int
Maximum number of namespaces supported.
max_io_request: int
IO Queue high water marker throttle
transfer_size: int
Maximum IO request Xfer size in 1K bytes maximum 1024
io_command_id_size: int
Number of command IDs per submission queue
io_cpl_queue_size: int
NVMe number of IO completion queue entries
io_sub_queue_size: int
NVMe number of IO submission queue entries
admin_cpl_queue_size: int
NVMe number of Admin completion queue entries
admin_sub_queue_size: int
NVMe number of Admin submission queue entries.
max_prp_list: int
Maximum number of PRP lists supported.
nvme_force_intx: int
Force using INTX mode instead of MSIx.
nvme_log_level: int
Log level.
1 - error
2 - warning
3 - info (default)
4 - verbose
This is with the latest ESX (6.0.0 # 1 SMP Release build-3073146 Sep 16 2015)
Community Manager
I think I need to understand again what you have in your system. The SSD 750 should be visible as a data drive. Does it show in system BIOS?
You said "On this box, I have two SATA SSDs, a Intel 3700 and this drive. The 3700 shows up fine."
The SSD 750 is not SATA and the correct hardware and bios settings are required to support it. If the drive looks like a SATA then you have the 2.5" version and will need a proper HBA or U.2 cable to connect it to. If a drive bay is used the system will need an Intel(R) Xeon(tm) E5 "v3" processor to have the PCIe lanes routed in the drive bays.
To confirm can you provide the SSD model# and the motherboard or system model you are using.
SChan70
Sorry I mis-wrote. It is a PCIe drive (and not the 2.5" version) - please globally replace SATA with PCIe in my message.
It is showing up as NVM-Express PCIe SSD, Device ID: 953, Sub Device ID: 370D, Class ID: 108, Vendor ID: 8086
Its a Super Micro SYS-2028TP-DTTR
Thanks Warren
SChan70
~ # vmkvsitools lspci | grep SSD
0000:81:00.0 Mass storage controller: Intel Corporation NVM-Express PCIe SSD [vmhba2]
Thouogh hba2 does not show up in storage list
~ # esxcli storage core adapter list
HBA Name Driver Link State UID Description
vmhba38 ahci link-n/a sata.vmhba38 (0:0:31.2) Intel Corporation Wellsburg AHCI Controller
vmhba39 ahci link-n/a sata.vmhba39 (0:0:31.2) Intel Corporation Wellsburg AHCI Controller
vmhba0 ahci link-n/a sata.vmhba0 (0:0:17.4) Intel Corporation Wellsburg AHCI Controller
vmhba1 ahci link-n/a sata.vmhba1 (0:0:31.2) Intel Corporation Wellsburg AHCI Controller
vmhba32 ahci link-n/a sata.vmhba32 (0:0:17.4) Intel Corporation Wellsburg AHCI Controller
vmhba33 ahci link-n/a sata.vmhba33 (0:0:17.4) Intel Corporation Wellsburg AHCI Controller
vmhba34 ahci link-n/a sata.vmhba34 (0:0:17.4) Intel Corporation Wellsburg AHCI Controller
vmhba35 ahci link-n/a sata.vmhba35 (0:0:31.2) Intel Corporation Wellsburg AHCI Controller
vmhba36 ahci link-n/a sata.vmhba36 (0:0:31.2) Intel Corporation Wellsburg AHCI Controller
vmhba37 ahci link-n/a sata.vmhba37 (0:0:31.2) Intel Corporation Wellsburg AHCI Controller
Rescan did not help either
# esxcli storage core adapter rescan --all
