cancel
Showing results for
Search instead for
Did you mean:
Intel 750 ssd PCI-E Add In Card x3 with Intel 2600CP4?
BBakk
New Contributor
I was looking into purchasing 3 of the new Intel 750 SSD PCI-E Add In Cards but was wondering if maximum performance can be achieved when using them with the Intel 2600CP4 Server board. It has PCI-E Gen3. Though 5x 8-lanes (instead of 4) - this shouldn't be a problem right? secondly is there any chipset related specs I should be looking out for to determine compatibility?
Thank you for your thoughts!
1 REPLY 1
ASouz7
Valued Contributor
Hello B.Bakker,
The board is ok but is recommended that you check for UEFI support.
Server OS'es are not supported with this SSD.
