Community
cancel
Showing results for
Search instead for
Did you mean:
firen
Intel 750 ssd on Evga X79 Dark mobo with 3930k
Hello Guys
i am deciding to buy the intel 750 pcie ssd and i was wondering if i can get the full speeds of the ssd or not.you can find my pc specs below;
CPU : intel 3930k 40 Pci Lanes
mobo : Evga X79 Dark
as you know 3930k is not officially support the gen 3.0 but my mobo Evga X79 Dark has Pcie gen 3.0 slots .So what will happen if i place my intel 750 ssd into one of the pcie gen 3.0 slots?is it going to run in gen 3.0 standarts or gen 2.0 standarts?
i am a little bit confused about that.I mean , is the ssd going to work as gen 3.0 even if the cpu officialy doesnt support pcie 3.0 ? or is it just going to need x4 available pci lanes in CPU?
or is it just going to take attention the slot that it has been running in?
Kind Regards
AP16
Valued Contributor III
Some motherboards vendors have an option in BIOS to force gen 3.0 mode even on officially unsupported Intel CPUs, check MB manual and/or ask EVGA support about it.
firen
yes the motherboard has pcie gen 3.0 slots and i can set them up in which mode (gen 2.0 or gen 3.0) they will run at.But as you know the intel 750 400gb is a little bit pricey so i just need to be sure that the intel 750 is going to work at its full speeds
AP16
Unfortunately, i`m personally seen no success reports with your exact MB model, but some X79-based MBs was able to run 750 at PCIE 3.0 level.
On 2.0 likely only linear read performance will be visible hurt.
firen
what if had 4930k instead of 3930k ? as you know 4930k supports gen 3.0 officially.my concern is here 3930k doesnt support gen 3.0 officially but it is capable of supporting gen 3.0
AP16
Spirit_Rises Special for you, 750 on Intel DX79SR board with no option to force PCIE Gen3 + Core i7 3960X 3.3Ghz :
C:\isdct>isdct.exe show -a -intelssd 0
- IntelSSD [removed] -
AggregationThreshold: 0
Aggregation Time: 0
ArbitrationBurst: 0
AsynchronousEventConfiguration: 0
Bootloader: 8B1B0131
ControllerDescription: @oem25.inf,%pci\\ven_8086&dev_0953.devicedesc%;Intel(R) Solid-State Drive P3700/P3600/P3500/750 Series
ControllerIDEMode: False
ControllerManufacturer: @oem25.inf,%intel%;Intel
ControllerService: IaNVMe
DevicePath: \\\\.\\PHYSICALDRIVE0
DeviceStatus: Healthy
DriverDescription: Intel(R) Solid-State Drive P3700/P3600/P3500/750 Series
DriverMajorVersion: 1
DriverManufacturer: Intel
DriverMinorVersion: 3
EnduranceAnalyzer: Note: Workload did not induce any wear on the drive. Expected life calculation is invalid. Ensure that workloads run for an hour or more for valid calculations.
ErrorString:
Firmware: 8EV10174
FirmwareUpdateAvailable: The selected Intel SSD contains current firmware as of this tool release.
HighPriorityWeightArbitration: 0
Index: 0
IOCompletionQueuesRequested: 0
IOSubmissionQueuesRequested: 30
LatencyTrackingEnabled: False
LBAFormat: 3
LedIdleState:
LedDurationBase:
LedOffDurationFormatMultiplier: 0
LedOnDurationFormatMultiplier: 0
LedOffDurationIoMultiplier: 0
LedOnDurationIoMultiplier: 0
LowPriorityWeightArbitration: 0
ProductFamily: Intel SSD 750 Series
MaximumLBA: 293028245
MediumPriorityWeightArbitration: 0
MetadataSetting: 0
ModelNumber: INTEL SSDPEDMW012T4
NativeMaxLBA: 293028245
NumErrorLogPageEntries: 63
NumLBAFormats: 6
NVMePowerState: 0
PCILinkGenSpeed: 3
PCILinkWidth: 4
PhysicalSize: 1200243695616
PowerGovernorMode: 0 (25W)
ProtectionInformation: 0
ProtectionInformationLocation: 0
RAIDMember: False
SectorSize: 4096
SerialNumber: [removed]
SMBusAddress: 106
SystemTrimEnabled: True
TempThreshold: 85 degree C
TimeLimitedErrorRecovery: 0
TrimSupported: True
WriteAtomicityDisableNormal: 0
C:\isdct>systeminfo
Host Name: DESKTOP-CFESGEE
OS Name: Microsoft Windows 10 Pro
OS Version: 10.0.10586 N/A Build 10586
OS Manufacturer: Microsoft Corporation
OS Configuration: Standalone Workstation
OS Build Type: Multiprocessor Free
System Manufacturer:
System Model:
System Type: x64-based PC
Processor(s): 1 Processor(s) Installed.
[01]: Intel64 Family 6 Model 45 Stepping 7 GenuineIntel ~3301 Mhz
BIOS Version: Intel Corp. SIX7910J.86A.0650.2014.0307.0138, 07.03.2014
Looks like 750 (or Intel NVMe driver) just nevermind about host capabilities and always throw PCIE Gen3 mode . No boot, of course.
firen
thank you so mich for the information so it looks like it will run at full speeds.is it possible to do as ssd or crystal disk benchmark tests for reading and writing speeds?
and why did you say no boot option ? is it because of the motherboard ?
AP16
I can, but this have no sense, cause:
1.
2. This exact SSD is already tuned to databases performance (non-default sector size) and should not be used as reference from any point.
Yes, it cannot be used as boot drive, Intel X79 MBs was not conform with UEFI v. 2.3.1 spec (and probably lacks NVMe EFI driver in BIOS).
firen
is this the test you have personally done?
thanks again
AP16
Yes, it`s mine. Please don`t loose a note2: this SSD configuration is changed from default.
firen
what do you mean by the ssd configuration is changed from default?
and for the boot device isnt it up to the motherboard? so the guy in evga's forum mentioned that he can boot from intel 750 so it seems the boot process nvme up to motherboard?
AP16
Intel board do not support boot from 750 (old UEFI and so on). EVGA may be (if someone in EVGA make BIOS changes needed).
750 have a bunch of parameters, configurable via isdct.exe, some was changed from default values for databases tasks purpose. Nothing you need at home though.
Community Manager
Spirit,
You did not mention if you needed boot support. The drive should work as a data drive.
As PCIe 3.0 ? there is a good possibility but I have no experience with the EVGA x79.
However the Intel X79 chipset based boards don't have full NVMe boot support in BIOS. That was implemented and validated with X99, Z97 and now Z170 chipsets.
firen
would you please check the conversation link below and look at the post # 11
but i dont have any idea which spu he used ,i asked him and waiting for a reply
http://forums.evga.com/X79-series-UEFI-Intel-750-pcie-x4-SSD-compatibility-m2336771.aspx http://forums.evga.com/X79-series-UEFI-Intel-750-pcie-x4-SSD-compatibility-m2336771.aspx
Community Manager
I read through that link. It looks like in Post 21 he is using an Intel Core i7-4960 processor.
Officially that is the reply. "Support" is with validated hardware and that hardware is the i7-4960 and similar processors.
I have seen and used the SSD as a data drive on a DX79SI (Core i7-3960 processor) but that is not validation, just install. You would need to be prepared to go to a validated configuration if the performance doesn't meet your expectation.
