cancel
Showing results for
Search instead for
Did you mean:
Intel D3-S4510 7.68 SSD : Can it be used on a Desktop PC
JimJim
New Contributor
Will this SSD work on a Desktop PC with standard SATA 3.0 running Linux 64-bit and Windows 10 Pro 64-bit?
Whereas, I need a high endurance drive for 4K Video Editing.
3 REPLIES 3
Esteban_C_Intel
New Contributor III
New Contributor III
JimJim,
The environment you are referring to is compatible with the product you are referring to.
The SATA 3.0 connection is compatible. Using this product on a desktop or server environment is possible. And the Operating Systems (OS) you mentioned should work just fine as well.
Answer given based on this product Intel® SSD D3-S4510 Series 7.68TB, 2.5in SATA 6Gb/s, 3D2, TLC
https://ark.intel.com/content/www/us/en/ark/products/134914/intel-ssd-d3-s4510-series-7-68tb-2-5in-s...
Anybody know where I can buy this drive from an authorized dealer? I can't find a purchase link at Intel, and all the ones I found on the Internet seem real shady with price varying from $1,400 to $$2,400. What is the actual retail price for this drive?
JimJim,
Maybe you can refer to the following link to find an authorized reseller:
https://www.intel.com/content/www/us/en/products/find-a-reseller.html
Esteban C
