Community
cancel
Showing results for
Search instead for
Did you mean:
KDoul
Intel DC 3600 NVME not showing delete support under ESXi 6?
Jump to solution
Intel DC 3600 Enterprise grade PCIe NVME SSD should support delete but it is not?
# esxcli storage core device vaai status get
t10.NVMe____INTEL_SSDPEDME400G4_*******__00000001
VAAI Plugin Name:
ATS Status: unsupported
Clone Status: unsupported
Zero Status: unsupported
Delete Status: unsupported
latest driver (intel-nvme-1.0e.2.0-1OEM.550.0.0.1391871.x86_64.vib), recent firmware
Message was edited by: Konstantin Doulepov remove serial#
Tags (1)
KDoul
https://github.com/vmware/nvme/issues/9 Intel DC 3600 NVME not showing delete support under ESXi 6 · Issue # 9 · vmware/nvme · GitHub
https://github.com/harderock harderock commented https://github.com/vmware/nvme/issues/9# issuecomment-220921963 an hour ago
Just found that on ESXi build 3620759, all vaai status are disabled by default, you can enable delete status by:
esxcli storage core device vaai status set -D 1 -d t10.xxxxxxxxxxxx
jbenavides
Hello Humay,
We advise you to try the 1.2.0.27-4 VMWare driver that can be obtained from http://www.vmware.com/resources/compatibility/detail.php?deviceCategory=io&productid=38469&deviceCat... VMware Compatibility Guide: I/O Device Search website.
Please be advised that the latest firmware 8DV10171 is required for this driver version.
https://downloadcenter.intel.com/product/80996/Intel-SSD-DC-P3600-Series-400GB-1-2-Height-PCIe-3-0-2... Drivers & Software
KDoul
jonathan_intel
Thanks for quick reply
Still no Delete status support
Checked Firmware was current: 8DV10171
vSphere Storage APIs for Array Integration +
# esxcli software vib list| grep nvme
nvme 1.2.0.27-4vmw.550.0.0.1331820 VMware VMwareCertified 2016-01-26
t10.NVMe____INTEL_SSDPEDME400G4*****
VAAI Plugin Name:
# esxcfg-scsidevs -l
t10.NVMe____INTEL_SSDPEDME400G4_____________________*****
Device Type: Direct-Access
Display Name: Local NVMe Disk (t10.NVMe____INTEL_SSDPEDME400G4_____________________*****)
Multipath Plugin: NMP
Console Device: /vmfs/devices/disks/t10.NVMe____INTEL_SSDPEDME400G4_____________________****
Devfs Path: /vmfs/devices/disks/t10.NVMe____INTEL_SSDPEDME400G4_____________________****__00000001
Vendor: NVMe Model: INTEL SSDPEDME40 Revis: 8DV1
SCSI Level: 6 Is Pseudo: false Status: on
Is RDM Capable: false Is Removable: false
Is Local: true Is SSD: true
Other Names:
vml.010000000043564d443531373430314a3434303041474e2020494e54454c20
VAAI Status: unsupported
also its shows as Parallel SCSI as transport
jbenavides
Hello Humay,
We would like to get additional information about this issue. Please check your private messages for further details about this matter.
KDoul
any news on Delete Status? Its takes too long to investigate?
jbenavides
Hello Humay,
We are currently looking into this, we will provide further updates as soon as they are available.
KDoul
month after ... hmm where updates? there is definitely bug in drivers something not right
KDoul
