cancel
Showing results for
Search instead for
Did you mean:
Intel DC D3700 Series dual port cables
SPolk
New Contributor
I have an Intel DC D3700 Series NVMe SSD (800GB) drive that I'm trying to get working in dual port mode. Is there any documentation on the DC D3700?
I've purchased two cables from SerialCables.com. I have the PCI-4339i-0.5M-N2 cable and the PCI-4339B-0.5M-N2 cable. The PCI-4339B-0.5M-N2 is PCI Sig compliant
but doesn't work at all with the D3700. The PCI-4339i-0.5M-N2 cable sort of works, but not reliably.
Does Intel have a specific cable to be used with this drive? Is the D3700 compliant with the SFF-TA-1001 specification? Any information would be helpful.
Stephen
7 REPLIES 7
SMuns
New Contributor
Hi
I don't need dual port what sort of cable do I need to connect this drive to Broadcom HBA 9400 16i Tri-Mode Adapter.
Shawn.
Esteemed Contributor III
Hi ShawnMunster,
This is the cable you need https://click.intel.com/sff-pcle-ssd-cable.html (SFF-8639 to SFF-8543). We recommend you to check with the hardware vendor(your HBA manufacturer) in order to validate it. Regards, Junior M.
Hi ShawnMunster,
We would like to know if you read our previous post. If you have any other questions, we'll be waiting for your response.Regards, Junior M.
