Community
cancel
Showing results for
Search instead for
Did you mean:
KElse
Intel DC P3600 reports 0 namespaces and health status *ASSERT_FFFF0194 SL
As the title says, my Intel DC P3600 reports 0 valid namespaces, and health status *ASSERT_FFFF0194 SL.
Registers are readable/writable, and identify controller succeeds (from which num ns and health status is read).
All other commands fails with Generic Error: Internal Device Error (SCT: 0, SC: 6).
As per the specification, an async event is posted on internal errors, and is fetched with an async event request. The async event request also fails with internal device error.
Is there any way of fixing this?
ASouz7
Hello Kristian-E,
In order for us to assist you, we need you to provide some important pieces of information.
  • What OS are you using?
  • Are you using the Intel(R) NVMe driver?
  • Can you dump the SMART values?
  • What test and/or activity was being run on the drive?
Using Intel Data Center Tool you can collect of number of dumps that can help us diagnose. Please save each dump to separate files.
isdct dump -destination /root/Desktop/ErrorLog.txt -intelssd X DataType=NVMelog LogID=1
This log shows the wearout indicator (100 = new, 1 = replace)
isdct dump -destination /root/Desktop/HealthLog.txt -intelssd X DataType=NVMelog LogID=2
isdct dump -destination /root/Desktop/FWrev.txt -intelssd X DataType=NVMelog LogID=3
isdct dump -destination /root/Desktop/SMARTdump.txt -intelssd X DataType=NVMelog LogID=202
Shows max temp. for warranty
isdct dump -destination /root/Desktop/TempSensor.txt -intelssd X DataType=NVMelog LogID=197
Drive Health
isdct dump -destination /root/Desktop/ID.txt -intelssd X DataType=Identify
KElse
Hi aleki_intel,
  • I am using Windows with the newest Intel(R) NVMe driver (v 1.1.0.1004), as well as Ubuntu 14.04 with the built-in driver, and an experimental OS
  • The disk has been used primarily for testing sequential/random reads across the entire drive
  • I have also performed a few experiments with sequential/random writes that sums to about 1 drive write over 5 days.
The Intel SSD Data Center Tool is unable to fetch the logs. All dump commands, except dump identify, fails with "Error: Selected drive is in a disable logical state",
I assume this is because the dump commands use the NVMe Get Log command, which fails with "Internal Device Error".
The dump identify partially succeeds, and I am able to get the "Identify Controller" data structure, which is uploaded as "ID.txt", the rest, probably "Identify Namespace" fails,
which to me makes sense since identify controller shows that there are 0 namespaces.
ASouz7
Hello Kristian-E,
Please, check your private messages.
KWang53
Hello aleki,
I have the same problem, could you help me? Thanks a lot!
Rgds,
Karr
ASouz7
Karr2000
In order for us to assist you, we need you to provide some important pieces of information as well as detailed information on your issue.
Drive Health
AZhu7
Hi aleki_intel,
I faced the same problem, as following:
- IntelSSD CVMD5172007E2P0EGN -
DeviceStatus: *ASSERT_FFFF0194 0G
Firmware: 8DV10171
FirmwareUpdateAvailable: Please contact Intel Customer Support for further assistance at the following website: http://www.intel.com/go/ssdsupport http://www.intel.com/go/ssdsupport.
ModelNumber: INTEL SSDPEDME020T4
ProductFamily: Intel SSD DC P3600 Series
Do you know how to fix it?
ASouz7
Aruanna.Zhu,
For this specific error: ASSERT_FFFF0194 0G we recommend to contact your nearest Intel Contact Center for live assistance from one of our technicians. Click on this link and choose the best way to contact us. http://www.intel.com/content/www/us/en/support/contact-support.html Contact Support
DYocu
Aleki,
I've got the same problem here, too. I've got 2 p3600 NVMe drives and one is in 'disable logical state' and DeviceStatus: *ASSERT_40351A10 9P. These are brand new drives that I purchased in R730xd servers from Dell a month ago.
Here are the particulars:
RHEL 7.1
# modinfo nvme
filename: /lib/modules/3.10.0-229.el7.x86_64/kernel/drivers/block/nvme.ko
version: 0.9
license: GPL
author: Matthew Wilcox <</span>mailto:willy@linux.intel.com willy@linux.intel.com>
rhelversion: 7.1
srcversion: D814A101C22ECEF7206A165
alias: pci:v*d*sv*sd*bc01sc08i02*
depends:
intree: Y
vermagic: 3.10.0-229.el7.x86_64 SMP mod_unload modversions
signer: Red Hat Enterprise Linux kernel signing key
sig_key: A3:CB:8C:C3:19:50:4A:B5:2C:FB:76:BA:F8:D8:A2:A7:39:68:9C:56
sig_hashalgo: sha256
parm: admin_timeout:timeout in seconds for admin commands (byte)
parm: io_timeout:timeout in seconds for I/O (byte)
parm: retry_time:time in seconds to retry failed I/O (byte)
parm: nvme_major:int
parm: use_threaded_interrupts:int
Attempting to run all the isdct dump commands you list above result in the same error message:
"Error: Selected drive is in a disable logical state."
How do I enable the drive??
Dan
mailto:dyocum@redhat.com dyocum@redhat.com
jbenavides
Hello Dan,
When the drive is in a disable logical state, it means that the drive detected a critical error and is locked. This is why it is not responding to ISDCT commands.
In this case, we advise you to contact our support center, please go to the http://www.intel.com/p/en_US/support/contactsupport Contact Support website, here you will find the contact methods available to engage a support engineer in your region.
DYocu
Got it. Thanks.
AZhu7
Hi dyocum,
I faced the same problem. Have you solved it?
AZhu7
Hi Kristian,
Have you fixed it? I face the same problem.
