Community
cancel
Showing results for
Search instead for
Did you mean:
MBrow33
Intel DC3700 SSD sudden failure
My DC3700 is suddenly showing a SMART failure and returns medium errors on all reads. It's on firmware 5DV10270.
I was using it in a desktop - I'm guessing that it's decided to return read errors for ALL reads since it's a DC drive and something happened.
If so, is there a way to tell it to go into consumer "best-effort" mode to get the data off of it?
JosafathB_Intel
Hello MBrow33, Thank you for contacting Intel® Memory & Storage Support. We noticed that you have an open case with our advanced technical support department that is related to the same issue, we will continue to provide you with support on that case. Thank you for your patience and understanding. Best regards, Josh B. Intel Customer Support Technician Under Contract to Intel Corporation
