cancel
Showing results for
Search instead for
Did you mean:
Intel Data Center tool not find my DC S3710 drive
LBirt
New Contributor II
Hi
I have a supermicro server with X10DRL-CT motherboard (C612 chipset). Two DC S3710 200gb SSD are connected to the standard S-ATA ports on the motherboard. On Centos 7.1 the Data Center Tool say no drive found. Why?
But work when I connect these SSDs to the LSI3108 controller (also on the motherboard).
Levi
6 REPLIES 6
LBirt
New Contributor II
- The controller is in AHCI mode, but I tried in RAID mode too...same result.
- They were connected to the 0,1 SATA ports
LBirt
New Contributor II
This is resolved by installing sg3-utils and modprobe sg ... or autoloading the sg module.
