cancel
Showing results for
Search instead for
Did you mean:
Intel Data Center tool not find my DC S3710 drive
LBirt
New Contributor II
Hi
I have a supermicro server with X10DRL-CT motherboard (C612 chipset). Two DC S3710 200gb SSD are connected to the standard S-ATA ports on the motherboard. On Centos 7.1 the Data Center Tool say no drive found. Why?
But work when I connect these SSDs to the LSI3108 controller (also on the motherboard).
Levi
6 REPLIES 6
jbenavides
Valued Contributor II
Hello birkosan,
Here are some initial recommendations that may help if Intel® Data Center Tool is not detecting your Intel® SSD DC S3710 when they are connected to the iRST ports of your motherboard.
- Make sure you are usinghttps://downloadcenter.intel.com/download/23931/Intel-Solid-State-Drive-Data-Center-Tool Intel® SSD Data Center Tool, version 2.3.0. Remember to run ISDCT with Root priviledges (Sudo command).
- Check with http://www.supermicro.com/support/index.cfm Super Micro Support and make sure you are using their most recent driver for your Intel® Chipset.
- Confirm that you are using the latest Firmware for your Intel® SSD DC S3710 (G2010140). You may connect it to the LSI* HBA and use ISDCT to update it if needed.
LBirt
New Contributor II
The intel driver could be the problem, but I doubt that. The latest fw and tool is installed.
I'll check the driver ...
LBirt
New Contributor II
I didn't find any linux driver for C612 chipset. Contacted supermicro too, but there is only for windows.
I tried with latest stable kernel (4.3.0), but not work.
So I think there is a bug in Data Center Tool. Where cand I fill a bug report?
jbenavides
Hello birkosan,
Please provide the following information:
- Is the storage controller set to RAID, or AHCI mode?
- Which ports are you using to connect the the drives? Try using the main ports if possible (I-SATA0 and I-SATA1)
If you wish to obtain direct assistance, you can engage a support agent in your region by following the instructions in the website: http://www.intel.com/p/en_US/support/contactsupport Contact Support
