Community
cancel
Showing results for
Search instead for
Did you mean:
TLerv
Intel NVMe driver for Windows 10?
Is there a preview available of the Intel NVMe driver for Windows 10?
My Intel 750 is stuck with the Microsoft NVMe driver since the current Intel NVMe driver seems to be invalid for Windows 10.
ASouz7
Hello Tore,
What is the exact error message you are getting ?
We have reports from other customers using the NVMe* drive successfully, however, full validation and support will only be provided after Windows 10* is officially released.
TLerv
After some researching I found out that I looked at the wrong thing in Device manager.
While the Intel disk uses the "Disk Drive" driver, the Storage controller further down uses the correct driver as described.
Everything seems to be as it should be.
ASouz7
Tore,
Thanks for letting us know. If you need any assistance, please do not hesitate to post here in communities or even contact us directly. http://www.intel.com/p/en_US/support/contactsupport Contact Support
