Community
cancel
Showing results for
Search instead for
Did you mean:
MNaep
Intel P3520 NVMe and HP ProLiant ML350 Gen9 - RSTe NVMe can not be installed
Jump to solution
Hello
I tried to install the latest Intel driver "RSTe NVMe 4.5.0.2125" on a HP ProLiant ML350 Gen9 Server with Windows Server 2016. But I receive an Error message "This computer does not meet the minimum requirements for installing the software". Hardware requirements should be ok (Intel Chipset C612 / P3520 SSD):
Thank you for your help.
Markus
MNaep
Hello everybody
After upgrading the Intel SSD DC P3520 to the latest firmware, I was able to install the Intel RSTe Software & Drivers. So now everything works fine.
Markus
Community Manager
Hello makeITbetter,
We understand that you're experiencing some installation issues in regards to the Intel® RSTe NVMe RAID Driver and two of your Intel® SSD DC P3520 Series.
Please keep in mind that the Intel® RSTe Driver has several additional requirements or limitations on top of your chipset and processor, as it does not support booting from RAID arrays, for example.
It's important to make sure that you've reviewed all the information provided in the following documents:
- http://www.intel.com/content/dam/support/us/en/documents/ssdc/ssd-software/RSTe_NVMeProduct%20Spec.p... Technical Product Specification (supported features, operating systems, and hardware).
- http://www.intel.com/content/dam/support/us/en/documents/ssdc/ssd-software/Intel_RSTe_NVMe_for_Windo... User Guide (Installation and RAID configuration steps).
If you're not interested in setting up your drives into a RAID array, then you may use our data center NVMe drivers instead:
- https://downloadcenter.intel.com/download/26451 Intel® SSD Data Center Family for NVMe Drivers.
Please let us know if this helps resolve your issue.
Carlos A.
MNaep
Hello everybody
Markus
Community Manager
makeITbetter,
We're glad to hear that your issue has been resolved. Thank you for sharing your solution with us.
If you need further assistance, please feel free to contact us again.
Carlos A.
