Community
cancel
Showing results for
Search instead for
Did you mean:
NQuig
Intel P3600 can't format between LBAFs
I have an Intel P3600 drive formatted to LBAF=2 (lbaf 2 : ms:16 ds:9 rp:0x2 (in use)). I can no longer format to different LBAFs. Drive FW is 8DV101F0, which I believe is the latest. This persists across reboots, power cycles, etc.
[root@VLUNnvme ~]# nvme id-ns /dev/nvme2n1 -n 1
NVME Identify Namespace 1:
nsze : 0x2e9390b0
ncap : 0x2e9390b0
nuse : 0x2e9390b0
nsfeat : 0
nlbaf : 6
flbas : 0x12
mc : 0x1
dpc : 0x11
dps : 0
nmic : 0
rescap : 0
fpi : 0
nawun : 0
nawupf : 0
nacwu : 0
nabsn : 0
nabo : 0
nabspf : 0
nvmcap : 0
nguid : 00000000000000000000000000000000
eui64 : 0000000000000000
lbaf 0 : ms:0 ds:9 rp:0x2
lbaf 1 : ms:8 ds:9 rp:0x2
lbaf 3 : ms:0 ds:12 rp:0
lbaf 4 : ms:8 ds:12 rp:0
lbaf 5 : ms:64 ds:12 rp:0
lbaf 6 : ms:128 ds:12 rp:0
[root@VLUNnvme ~]# nvme format /dev/nvme2n1 -lbaf 1
Success formatting namespace:1
nsze : 0x2e9390b0
ncap : 0x2e9390b0
nuse : 0x2e9390b0
nsfeat : 0
nlbaf : 6
flbas : 0x12
mc : 0x1
dpc : 0x11
dps : 0
nmic : 0
rescap : 0
fpi : 0
nawun : 0
nawupf : 0
nacwu : 0
nabsn : 0
nabo : 0
nabspf : 0
nvmcap : 0
Community Manager
NickQuigley,
Considering the information you have sent us, could you please try to format it by using the following tool:https://downloadcenter.intel.com/download/26221/Intel-SSD-Data-Center-Tool?product=87278 Intel® SSD Data Center Tool and execute the NVMe* format stating on page # 39 through # 42 of this guide: http://www.intel.com/content/dam/support/us/en/documents/solid-state-drives/ssd-software/Intel_SSD_D... Intel® Solid State Drive Data Center Tool - User Guide
Let us know if this helped you.
Aleki
NQuig
Hi Aleki,
This didn't address the issue. Here is the identify namespace info showing that we are using LBAF=2
[root@vlun200 ~]# isdct show -identify -namespace 1 -intelssd 0
- Identify Namespace CVMD449200B7400FGN -
- Byte 0-7 -
Namespace Size : 781422768
- Byte 8-15 -
Namespace Capacity : 781422768
- Byte 16-23 -
Namespace Utilization : 781422768
- Byte 24 -
Namespace Features : 0
Bit 7:1 - Reserved : 0
Bit 0 - Thin Provisioning Support : 0
- Byte 25 -
Number of LBA Formats : 6
- Byte 26 -
Formatted LBA Size : 12
Bit 7:5 - Reserved : 0
Bit 4 - Metadata transfer bit : 1
Bit 0:3 - LBA Format Support : 2
I then do the format to LBAF=0
[root@vlun200 ~]# isdct start -intelssd 0 -nvmeformat LBAFormat=0 ProtectionInformation=0
WARNING! You have selected to format the drive!
Proceed with the format? (Y|N): y
Formatting...
- Intel SSD DC P3600 Series CVMD449200B7400FGN -
Status : NVMeFormat successful.
But after the format, the namespace still uses LBAF=2
- Byte 0-7 -
- Byte 8-15 -
- Byte 16-23 -
- Byte 24 -
- Byte 25 -
- Byte 26 -
Community Manager
NickQugley,
Thank you for the clarification. In this particular case we are going to engage additional resources to address this situation. In the mean time, please let us know if there any other piece of relevant information you would like to share.
Aleki
Community Manager
NickQuigley,
Thank you for your time. Could you please confirm that this drive is attached to the board or are you using something else such as a RAID controller? If so, could you please be so kind and use it directly on the board and trey a secure erase?
Please let us know the results as soon as you can.
Aleki
NQuig
Aleki,
Yes, this drive is directly attached to the board. Secure Erase didn't help:
Before Secure Erase:
[root@VLUN127 Drive FW]# isdct show -identify -namespace 1 -intelssd 0
- Byte 0-7 -
- Byte 8-15 -
- Byte 16-23 -
- Byte 24 -
- Byte 25 -
- Byte 26 -
Secure Erase:
[root@VLUN127 Drive FW]# isdct start -intelssd 0 -nvmeformat SecureEraseSetting=1
Formatting...
Format to LBAF=0:
[root@VLUN127 Drive FW]# isdct start -intelssd 0 -nvmeformat LBAFormat=0 ProtectionInformation=0
Formatting...
Check again, and we are still at LBAF=2
- Byte 0-7 -
- Byte 8-15 -
- Byte 16-23 -
- Byte 24 -
- Byte 25 -
- Byte 26 -
-Nick
Community Manager
NickQuigley,
Thank for the report, based on this, could you please be so kind run the tool found in this link: https://github.com/linux-nvme/nvme-cli
Follow the steps found in this very website so you can use it to install the source for the distribution you intend to use. Use the command to format found in this link: https://github.com/linux-nvme/nvme-cli/blob/master/Documentation/nvme-format.txt
Here is an example nvme format /dev/nvme0n1 and check the LBAF is set to 0.
Let us know if this helped you,
Aleki
NQuig
Aleki,
This did not help either:
[root@vlun118 ~]# nvme id-ns /dev/nvme1n1 -n 1 | grep lbaf
nlbaf : 6
[root@vlun118 ~]# nvme format /dev/nvme1n1 -n 1 -l 0 -i 0
nlbaf : 6
Would it be helpful to RMA one of the drives exhibiting this behavior? This is being done in an engineering/QA environment so we would be open to returning a drive on an RMA if it helps root cause the issue.
-Nick
Community Manager
NickQuigley,
Thank you for taking the time and trying the steps suggested. We are going to inform your results to our engineering department and will get back to you as soon as possible.
Aleki
Community Manager
NickQuigley,
Thank you for your time. In order for us to move into the next step, there is some information we need in order to provide all the support you need. Could you please be so kind and look at the private message we have sent you?
Aleki
