Community
cancel
Showing results for
Search instead for
Did you mean:
GGil
Intel P3700 blinking orange led
Hi All,
I've recently bought Intel's P3700 800GB SSD to our Lenovo x3650 M5 (E5-2630 v3 dual CPU) server, running Ubuntu.
Performance is not as high as it suppose to be - hdparm -tT --direct shows around 1.6GB/sec. The same drive on a friends PC shows the 2.8GB/sec it suppose to be.
While trying to debug it I've noticed that the first orange led is blinking steadily - half a second on, half a second off, etc... It is starting when Ubuntu is booting even when the drive is not mounted so there is no traffic.
I tried to shutdown the server and unplug the power sources - but no luck there.
After installing the disk i ran dd if=/dev/zero of=/dev/nvme0n1 bs=1M oflag=direct, like it suggested in the NVMe Driver Reference Guide - maybe I put the SSD is some kind of bad state?
Any other ideas? Maybe firmware? how do I find out which firmware I have? Unfortunately Intel does not support Ubuntu for the SSD Data Center Tool.
I'm do not know if the blinking causes the performance issue, but it is odd.
Gil.
Tags (1)
MGant
Maybe your SSD model is failing. http://www.dafotec.fr/ To see the chip controller you have to open it but it will void the warranty.http://www.dafotec.be/
GGil
I just want to correct something, I didn't try the drive I have on my friends PC, he has a different P3700.
rookie67, I hope you are wrong
Community Manager
Gilsho,
About this situation, for Ubuntu you can go ahead and download the Intel® SSD Data Center Tool for Linux* here: https://downloadcenter.intel.com/download/23931/ https://downloadcenter.intel.com/download/23931/
Also, here are the commands for you to use the Intel® SSD Data Center data http://www.intel.com/content/dam/support/us/en/documents/solid-state-drives/ssd-software/Intel_SSD_D... http://www.intel.com/content/dam/support/us/en/documents/solid-state-drives/ssd-software/Intel_SSD_D...
As well, the activity light will blink anytime there is activity, please refer to the last page from this document: http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-dc-p3700-spec... http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-dc-p3700-spec...
Let us know if you still require assistance.
GGil
First of all, thank you for the quick response,
1. The Linux package contains RPM installation files which doesn't suite Ubuntu. Is there an Ubuntu/Debian installation somewhere?
2. If it is true I do not understand why there is I/O activity. It is a fresh install of Ubuntu and I didn't even mount the SSD so I do not expect any traffic towards it. I'll try to investigate it from the OS side.
GGil
UPDATE
I've unpacked the .rpm files and they are running fine. I spotted that my SSD is on an "EnduranceAnalyzer" mode, and it is waiting for an hour of workload for endurance analysis. Can this cause the performance issues I have? Is there a way to disable this analyzer? I'm running a random read/write workload for over an hour and the analyzer still doesn't have sufficient data.
This is the output of isdct show -a -intelssd 0, is there something bad here?
AggregationThreshold : 0
AggregationTime : 0
ArbitrationBurst : 0
Bootloader : 8B1B0131
CoalescingDisable : 1
DevicePath : /dev/nvme0n1
DeviceStatus : Healthy
EndToEndDataProtCapabilities : 17
EnduranceAnalyzer : Media Workload Indicators have reset values. Run 60+ minute workload prior to running the endurance analyzer.
ErrorString :
Firmware : 8DV10171
FirmwareUpdateAvailable : The selected Intel SSD contains current firmware as of this tool release.
HighPriorityWeightArbitration : 0
IOCompletionQueuesRequested : 30
IOSubmissionQueuesRequested : 30
Index : 0
Intel : True
IntelGen3SATA : False
IntelNVMe : True
InterruptVector : 0
LBAFormat : 0
LatencyTrackingEnabled : False
LowPriorityWeightArbitration : 0
MaximumLBA : 1562824367
MediumPriorityWeightArbitration : 0
MetadataSetting : 0
ModelNumber : INTEL SSDPEDMD800G4
NVME_1_0_Supported : True
NVME_1_2_Supported : False
NVMeControllerID : 0
NVMePowerState : 0
NamespaceId : 1
NativeMaxLBA : 1562824367
NumErrorLogPageEntries : 63
NumLBAFormats : 6
OEM : Generic
PCILinkGenSpeed : 3
PCILinkWidth : 4
PowerGovernorMode : 0 25W
Product : Fultondale
ProductFamily : Intel SSD DC P3700 Series
ProductProtocol : NVME
ProtectionInformation : 0
ProtectionInformationLocation : 0
SMARTHealthCriticalWarningsConfiguration : 0
SMBusAddress : 106
SectorSize : 512
SerialNumber : CVFT6042001W800CGN
TCGSupported : False
TempThreshold : 85
TimeLimitedErrorRecovery : 0
TrimSupported : True
VolatileWriteCacheEnabled : False
WriteAtomicityDisableNormal : 0
Gil.
Community Manager
Gilsho,
Thanks for replying back and trying the steps provided. We would like you to try the following in order to try to reset the endurance analyzer:
1. Reset SMART Attributes using the reset option.
isdct.exe set –intelssd 2 enduranceanalyzer=reset
2. Optionally, remove the SSD and install in test system.
3. Apply minimum 60-minute workload to SSD.
4. Reinstall SSD in original system if needed. Compute endurance using the show command. You can also specify the EnduranceAnalyzer property specifically using the –display (-d) option.
isdct.exe show –a –intelssd 2
isdct.exe show –d EnduranceAnalyzer –intelssd 2
5. Read the Endurance Analyzer value which represents the drive's life expectancy in years.
About the performance on this SSD, please make sure you are using our https://downloadcenter.intel.com/download/23929/Intel-SSD-Data-Center-Family-for-NVMe-Drivers NVMe driver.
We will be waiting for your response, have a nice day.
GGil
I've reset the Endurance Analyzer, and rerun my workload and got the "wear prediction" - so thanks for that.
I'm using Ubuntu 14.04 with 4.2.0 Kernel, so NVME driver was compiled as a module by default:
filename: /lib/modules/4.2.0-27-generic/kernel/drivers/block/nvme.koversion: 1.0license: GPLauthor: Matthew Wilcox <</span>mailto:willy@linux.intel.com willy@linux.intel.com>srcversion: C1E91880F29AB152ED05CF5alias: pci:v*d*sv*sd*bc01sc08i02*
1. The orange light is still blinking even though there is no traffic to the SSD.
2. I'll try to be more clear about the bandwidth problem I'm talking about:
I'm running fio with simple synchronous read of a big file in the P3700. I had the chance to run it on a PC (i7-5930K) which showed the desired 2.8GB/sec bandwidth. On the other hand, on our new server (2x Xeon E5-2630v3) for the same test I get a 1.5GB, the same happened on another server I used to work on (4x E5-4650v2). I wonder what is different in the server that doesn't fully utilize the fast storage bandwidth.
Community Manager
Glisho,
We would like to know the model of each server you have tested so far. It seems it could be related to some configuration from each server and we would like to learn more about the specs on each one.
GGil
This is the spec for my current working server:
Ubuntu 14.04 with 4.2.0-27 Kernel
Processor Information
Socket Designation: Socket 1/2
Type: Central Processor
Family: Xeon
Manufacturer: Intel(R) Corporation
ID: F2 06 03 00 FF FB EB BF
Signature: Type 0, Family 6, Model 63, Stepping 2
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
DS (Debug store)
ACPI (ACPI supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
SS (Self-snoop)
HTT (Multi-threading)
TM (Thermal monitor supported)
PBE (Pending break enabled)
Version: Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz
Voltage: 1.6 V
External Clock: 100 MHz
Max Speed: 4000 MHz
Current Speed: 2400 MHz
Status: Populated, Enabled
Upgrade:
Serial Number: Not Specified
Asset Tag: Unknown
Part Number: Not Specified
Core Count: 8
Core Enabled: 8
Thread Count: 8
Characteristics:
64-bit capable
Multi-Core
Hardware Thread
Execute Protection
Enhanced Virtualization
Power/Performance Control
BIOS Information
Vendor: LENOVO
Version: -[TCE106KUS-1.10]-
Release Date: 04/17/2015
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 16384 kB
Characteristics:
PCI is supported
PNP is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
LS-120 boot is supported
ATAPI Zip drive boot is supported
Function key-initiated network boot is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 1.10
Firmware Revision: 1.72
System Information
Manufacturer: LENOVO
Product Name: System x3650 M5: -[5462E4G]-
Base Board Information
Product Name: 00YJ423
Version: SVT
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: Rack-mount
Type: Motherboard
PCI Devices
00:03.0 PCI bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 3 (rev 02)
00:03.2 PCI bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 3 (rev 02)
00:05.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Address Map, VTd_Misc, System Management (rev 02)
00:05.1 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Hot Plug (rev 02)
00:05.2 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 RAS, Control Status and Global Errors (rev 02)
00:05.4 PIC: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 I/O APIC (rev 02)
00:11.0 Unassigned class [ff00]: Intel Corporation C610/X99 series chipset SPSR (rev 05)
00:14.0 USB controller: Intel Corporation C610/X99 series chipset USB xHCI Host Controller (rev 05)
00:16.0 Communication controller: Intel Corporation C610/X99 series chipset MEI Controller # 1 (rev 05)
00:16.1 Communication controller: Intel Corporation C610/X99 series chipset MEI Controller # 2 (rev 05)
00:1a.0 USB controller: Intel Corporation C610/X99 series chipset USB Enhanced Host Controller # 2 (rev 05)
00:1c.0 PCI bridge: Intel Corporation C610/X99 series chipset PCI Express Root Port # 1 (rev d5)
00:1c.2 PCI bridge: Intel Corporation C610/X99 series chipset PCI Express Root Port # 3 (rev d5)
00:1c.4 PCI bridge: Intel Corporation C610/X99 series chipset PCI Express Root Port # 5 (rev d5)
00:1d.0 USB controller: Intel Corporation C610/X99 series chipset USB Enhanced Host Controller # 1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation C610/X99 series chipset LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation C610/X99 series chipset 6-Port SATA Controller [AHCI mode] (rev 05)
00:1f.3 SMBus: Intel Corporation C610/X99 series chipset SMBus Controller (rev 05)
00:1f.6 Signal processing controller: Intel Corporation C610/X99 series chipset Thermal Subsystem (rev 05)
10:00.0 Non-Volatile memory controller: Intel Corporation PCIe Data Center SSD (rev 01)
7f:08.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 QPI Link 0 (rev 02)
7f:08.2 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 QPI Link 0 (rev 02)
7f:08.3 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 QPI Link 0 (rev 02)
7f:0b.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring (rev 02)
7f:0b.1 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring (rev 02)
7f:0b.2 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring (rev 02)
7f:0c.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers (rev 02)
7f:0c.1 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers (rev 02)
7f:0c.2 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers (rev 02)
7f:0c.3 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers (rev 02)
7f:0c.4 System peripheral: I...
GGil
And some more info about the PCI devices:
00:00.0 Host bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DMI2 (rev 02)
Subsystem: Device 1d49:0a00
Flags: fast devsel
Capabilities: [90] Express Root Port (Slot-), MSI 00
Capabilities: [e0] Power Management version 3
Capabilities: [100] Vendor Specific Information: ID=0002 Rev=0 Len=00c <?>
Capabilities: [144] Vendor Specific Information: ID=0004 Rev=1 Len=03c <?>
Capabilities: [1d0] Vendor Specific Information: ID=0003 Rev=1 Len=00a <?>
Capabilities: [280] Vendor Specific Information: ID=0005 Rev=3 Len=018 <?>
Capabilities: [300] Vendor Specific Information: ID=0008 Rev=0 Len=038 <?>
00:01.0 PCI bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 1 (rev 02) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0
Bus: primary=00, secondary=01, subordinate=05, sec-latency=0
Capabilities: [40] Subsystem: Device 1d49:0a00
Capabilities: [60] MSI: Enable+ Count=1/2 Maskable+ 64bit-
Capabilities: [90] Express Root Port (Slot+), MSI 00
Capabilities: [110] Access Control Services
Capabilities: [148] Advanced Error Reporting
Capabilities: [250] # 19
Kernel driver in use: pcieport
00:02.0 PCI bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 2 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=06, subordinate=0a, sec-latency=0
00:02.2 PCI bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 2 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=0b, subordinate=0f, sec-latency=0
00:03.0 PCI bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 3 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=10, subordinate=14, sec-latency=0
Memory behind bridge: 90200000-902fffff
00:03.2 PCI bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 3 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=15, subordinate=19, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: 90300000-904fffff
Flags: fast devsel
Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
Flags: fast devsel
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [100] Vendor Specific Information: ID=0006 Rev=1 Len=010 <?>
Capabilities: [110] Vendor Specific Information: ID=0006 Rev=1 Len=010 <?>
Capabilities: [120] Vendor Specific Information: ID=0006 Rev=1 Len=010 <?>
Capabilities: [130] Vendor Specific Information: ID=0006 Rev=1 Len=010 <?>
Flags: fast devsel
00:05.4 PIC: In...
Community Manager
Gilsho,
Thanks for providing the information. We would like to know, are the other servers you have tested also Lenovo* servers?
If those are also Lenovo* we suggest you to contact them in order to verify the change on the speed since we do know the SSD works fine in one of them.
Please keep us updated, we will be waiting.
Community Manager
Gilsho,
We are following up this case and we would like to know if you contacted Lenovo* about the situation?
We will be waiting for your response.
NC
GGil
I've posted a question on Lenovo forums, but no one answered.
https://forums.lenovo.com/t5/System-x-Rack-Servers/Lenovo-x3650-M5-and-Intel-P3700-SSD-Performance-I... Lenovo x3650 M5 and Intel P3700 SSD - Performance ... - Lenovo Community
I also trying to debug it on my own, but still on luck.
Community Manager
Gilsho,
Thanks for replying back. We would like you to check with Lenovo* as you said the drive was running fine in other servers and at the same time it will be important to have some inputs from them about the situation you have.
Please let us know if you receive any update.
NC
GGil
Update
I took a friend's SSD from another server and connected it to my server.
My friend's SSD orange led doesn't blink, so it seem like a SSD issue and not a server issue.
Performance on my friend's SSD is higher - 1.6GB/sec on my sync fio benchmark, while my SSD show almost 1.2GB/sec.
This is still not peak performance, but SSDs performance should be the same, mine is even newer so wear level and stuff are low.
The only difference I can think of between SSDs are the firmware: mine is 8DV10171 while his is 8DV10131.
I will really want to solve the orange blinking led issue, it shouldn't happen.
Please advise,
Gil.
Community Manager
Gilsho,
Thanks for the testing on your end.
We would like to review a little bit more on this since you have tested another SSD which light does not blink.
We will get back to you as soon as we confirm this behaviour, we will try both firmwares if possible as well.
NC
KDoul
I have same issue P3600 here, amber LED is blinking all the time (its first LED from top - amber, others are red and yellow silent, green is ON also), no problems with data so far. My drive usage is very low. OS is VMWARE ESXi with latest driver. Server is HP Microserver Gen 8.
When in POST or in BIOS Setup LED is OFF
When Vmware driver loaded amber is blinking when Intel driver loaded -constant solid amber
Update:
https://github.com/vmware/nvme/issues/10 Intel P3600 constant blinking amber led · Issue # 10 · vmware/nvme · GitHub
can it be forwarded to Intel ESXI driver development team?
Community Manager
Humay,
Please check your private message. Let us know.
Community Manager
The SSD model, server, configuration and test settings are all important for performance results. If the conditions are not the same, then we would expect different results. The advertised values are noted in pages 10-11 of the http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-dc-p3700-spec... P3700 product specifications.
Make sure that the drive is preconditioned, since that also has an impact in the performance results.
It is advised to check with Lenovo for any BIOS updates as well.
Here are some existing threads and reference documents about NVME* drive performance:
/thread/76405 Anyone measured the performance of NVMe PCIe 750 SSD using fio under Linux?
/thread/56790 Intel DC P3700 400GB SSD Poor performance on linux system
http://www.intel.com/content/dam/support/us/en/documents/ssdc/hpssd/ssd-750/sb/intel_ssd_750_series_... http://www.intel.com/content/dam/support/us/en/documents/ssdc/hpssd/ssd-750/sb/intel_ssd_750_series_...
http://itpeernetwork.intel.com/how-to-benchmark-ssds-with-fio-visualizer/ http://itpeernetwork.intel.com/how-to-benchmark-ssds-with-fio-visualizer/
JB
GGil
What do you mean by "preconditioned"?
But the conditions are the same between both SSDs I have tested. And still, why that orange led is blinking?
