Community
cancel
Showing results for
Search instead for
Did you mean:
CChon3
Intel P3700 compatibility with Z97 motherboard
Does the P3700 SSD actually populate values into Intel SMBus slave device 53h?
I have this SMBus issue on one Z97 motherboard (ASUS Maximus VII Gene) but not on another Z97 motherboard (ASROCK Z97M Pro 4).
As far as I know, 53h is supposed to contain DIMM SPD data for memory slot B2, when any RAM is populated in slot B1/B2 while the P3700 SSD is populated in any of the PCI Express slots on the Maximus VII Gene motherboard will result in a memory error (no boot).
I am trying to figure out who should I be looking for a fix to this issue, Intel or Asus?
Jose_H_Intel1
Do you know if the BIOS from the ASUS motherboard support UEFI 2.3.1?
CChon3
I do. Running the UEFI Shell on my ASUS motherboard, I type in "ver" from the EFI Shell prompt, this is the result:
EFI Specification: 2.31
EFI Vendor: American Megatrends
EFI Revision: 4.655
Jose_H_Intel1
I managed to get some answers to the questions you asked above:
  1. Yes, PCIe SSD's are technically 'memory' devices.
  2. The change to correct this will most likely need to come from ASUS. We do not currently have a Maximus VII Gene board, but we will test a similar configuration to see if we can recreate this issue.
CChon3
1. Why does it have to be 53h (and not somewhere else)? I am pretty sure all the recent PCHs (Cougar Point, Panther Point, Lynx Point) use 50h-53h on the SMBus for DIMM SPD data. I know that Patsburg (and maybe Wellsburg) is the exception to this (where DIMM SPD data is at a different location).
Jose_H_Intel1
Please allow us more time to investigate.
CChon3
Community Manager
53h is the correct location for the VPD (Vital Product Data) per the SSD Form Factor specification. The Intel® SSD DC P3700/P3600 series drives are targeted for Data Center Servers and Storage appliances. These systems generally use a MUX to allow multiple devices to share resources.
CChon3
One last question:
Will the P3700 work even if 3.3Vaux is not supplied by the system (as per Chapter 7.5, 2nd paragraph of Enterprise SSD Form Factor 1.0a Specification)?
http://www.ssdformfactor.org/docs/SSD_Form_Factor_Version1_a.pdf http://www.ssdformfactor.org/docs/SSD_Form_Factor_Version1_a.pdf
ASouz7
Hello ClementChong,
We are going to verify on this for you and will let you know soon. Please allow us some time to check further on this matter.
