Community
cancel
Showing results for
Search instead for
Did you mean:
SMuns
Intel P4500 U.2 SSD slow PCIe x1
I1
I have an Intel P4500 U.2 SSD, since last firmware update the drive has slowed down to PCIe x1 instead of x3.
The drive has no errors, it just the speed that is slow.
any command I need to run in isdct to fix this?
Shawn
Community Manager
Hi ShawnMunster,
Thank you for posting in the Intel communities.
I understand that you are expericing a slow down on the PCIe interface after the firmware was updated. I've checked the log file attached to the post, but I'd like to ask you if you can run the following command and attach the output here so I can take a look at it:
isdct show -a -intelssd
This command will give us additional information about the drive.
Note: If you are not sure about the SSD index number, run first the command isdct show -intelssd to display all drives, then look for the index number of the drive in discussion and finally run the command mentioned above.
On the meantime, I'll check from my side if there is a specific command that can modify the actual speed the PCIe interface is working on. I know there is one for SATA drives, but I'm not sure if there is also a command for PCIe drives.
Additionally and just to confirm, have you changed the port the SSD is connected to after the firmware update? Usually, these kind of issues are because of the PCIe slot used which has a lower capacity than the actual device causing a slow down.
Another thing to consider is the NVMe* driver. Please make sure you have installed the latest driver version (4.0.0.1007) available here: https://downloadcenter.intel.com/download/27517?v=t
If you haven't updated the NVMe* driver, please do so and then run the command I mentioned at the beginning so that the data is collected with the latest driver installed and make sure the SSD is in the correct PCIe slot.
I'll be waiting for your response.
Have a nice day.
Diego V.
SMuns
Hi Diego V,
I have change ports and cables, PCIe slot nothing makes any difference. still slow.
Here is output requested.
Shawn.
SMuns
Hi Diego V,
Some more info attached just in case SSU.
Shawn.
JUAN_N_Intel
Hi Shawn,
Thank you for the information. I can see from the report attached that you have the latest NVMe* driver installed. However, there is an interesting thing that I noticed from the previous report and the new one.
If you check the first report that you shared, you will see at the end the "Current PCIe Link Speed" value which is 1. That means that drive was working as a PCIe 1.0 device. However, the same value appears in the new report as 3 which means the drive works now as a PCIe 3.0 device (it appears as "PCILinkGenSpeed"). I'm not sure about why it was different before (maybe the driver was updated?), but from the latest report it looks to be fine.
Please let me know how you are measuring the drive performance to make this conclusion.
From your original post, I understand you are talking about the PCIe lanes (x1, x4, x8, x16), but I'm not sure if you are referring to the PCIe gen instead. The reason of my confusion is because of the information in the reports that I explained above. Additionally, the interface of the drive you have is PCIe 3.1 x4 which means it's a PCIe gen 3 device and should be connected to a port with x4 lanes.
From the SSU report, I can see that you have a Z10PE-D8 WS motherboard and according to its specifications, it only has PCIe 3.0 x16 slots so the drive should work fine on these. Actually, that's reflected in the latest report from the Intel® SSD DCT (PCIe gen 3 x4 width). That makes me thing again about how you are measuring the drive speed because from the reports everything seems to be in order.
Have a nice day.
Diego V.
SMuns
Hi Diego V,
I change PCIe slot I get that report PCIe 3 x4 but speed is not there with Normal Intel NVME driver.
https://downloadcenter.intel.com/download/27517/Datacenter-NVMe-Microsoft-Windows-Drivers-for-Intel-... Datacenter NVMe* Microsoft Windows* Drivers for Intel® SSDs
Version 4.0.0.1007 of the Intel® SSD Data Center Family for NVMe* drivers.
with the above driver speed was only 1000 MB/s read 300 MB/s Write.
so I install Intel NVME Driver from RSTe it works better speed is now.
Shawn
SMuns
Hi Diego V,
Attached report from isdct show -a intelssd 0
Shawn
Community Manager
Hi Shawn,
If I understood you well, the drive achieves its normal performance when the RST driver is used rather than the regular NVMe* driver I mentioned at the beginning, right?
According to the information from Crystal Disk Mark, the results are the expected ones according to the following site: https://ark.intel.com/products/99030/Intel-SSD-DC-P4500-Series-1_0TB-2_5in-PCIe-3_1-x4-3D1-TLC?q=SSD...
Unless I'm missing something else, it seems that the drive is working fine now, correct? You can continue using those drivers as you are getting the expected performance of the drive.
Please let me know if there is anything else I can help you with.
Have a nice day.
Diego V.
SMuns
Hi Diego V,
I think there might be some sort conflict between HGST PCIe SN260 and Intel P4500 U.2 when using Intel NVME driver. look like the RSTE driver from this pack stops the conflict.
Shawn.
https://downloadcenter.intel.com/download/27984/Intel-Rapid-Storage-Technology-Intel-RST-User-Interf... Intel® Rapid Storage Technology (Intel® RST) User Interface and Driver
The Intel® RST UI supports system acceleration with Intel® Optane™ Memory as well as advanced features such as RAID management and Intel® Smart Response Technology (Intel® SRT). (16.5.1.1030)
DriversWindows Server 2016*
Windows 10, 32-bit*
Windows 10, 64-bit*16.5.1.1030
Latest7/19/2018
Community Manager
Hi ShawnMunster,
Thank you for the additional information. I'll forward it to the proper team so that they can check it.
Have a nice day.
Diego V.
