Community
cancel
Showing results for
Search instead for
Did you mean:
IBute
Intel Pro 2500 240GB SSD problem
Dear Support,
Intel Pro 2500 240GB SSD have a problems with read operations.
Than I have wiped it using Intel Toobox and Activa Kill disk.
After this SSD doesn't accept write operations.
I have attached screenshots with S.M.A.R.T.
Please let me know is it possible to recover this ssd to operational state or it completely dead?
Thanks in advance,
Igor
Community Manager
Hello ibutenko,
Thank you for contacting Intel® Technical Support.
As we understand, you need assistance with your Intel® SSD Pro 2500 Series If we infer correctly we will appreciate if you can provide us with the following information:
We will be looking forward to your reply.
Josh B.
Under Contract to Intel Corporation
IBute
Hi Josh!
Requested information attached.
Cheers,
Igor
Community Manager
Hello ibutenko,
Thank you for your reply.
We are going to be working in reviewing the information, pictures and the logs you provided, we will be contacting you back as soon as we have an update or in case that further information is required.
Thank you for your patience and understanding.
Josh B.
Community Manager
Hello ibutenko,
Thank you for your reply and the information provided.
You are going to receive an email shortly from our advance technical support department in order to further assist you.
Josh B.
IBute
Hello Josh!
Thank you for assistant!
Will wait for an answer from advance technical support department.
Cheers,
Igor
