Community
cancel
Showing results for
Search instead for
Did you mean:
sunswat
Intel S4500 디스크를 사용하고 있습니다. LSI3008-IR Controller 와 함께 사용하고 있습니다. LSI3008-IR controller에 S4500 1.9TB를 RAID 1 or 1+0 으로 사용하고 있습니다. 사용 중 Write 에 문제가 발생하였습니다. 52.2 MB/s 로 성능이 1/10로 느려지는 상황이 발생 하였습니다. 해결 방안을 부탁 드립니다.
JosafathB_Intel
Hello sunswat, Thank you for contacting Intel® SSD Support. In order to further assist you regarding your inquiry related to your Intel® SSD DC S4500 Series. We will appreciate if you can provide us with the following information: • The SSU logs. 1- Go to https://downloadcenter.intel.com/download/25293/ and download the software. 2- When finished downloading it, open it. 3- Attach the file obtained to your reply. • The SMART logs extracted from your Intel® SSD DC S4500 Series. The Intel’s Data Center Tool (DCT) can be used to read out the SMART attributes to download this tool please follow this link: https://downloadcenter.intel.com/download/28460/Intel-SSD-Data-Center-Tool-Intel-SSD-DCT-?product=87... We will be looking forward to your reply. Have a nice day. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
sunswat
Thank you for answer.
The same symptoms have occurred in our office tests.
In addition, our clients have tested in a variety of ways.
[method 1]
Intel SSD Firmware upgrade.
[method 2] LSI3008 Raid Controller Firmware upgrade, etc.
All of the same symptoms have occurred and did not occur on the Intel SSD S4510 Disk.
We will send you information.
JosafathB_Intel
Hello, sunswat, Thank you for your reply. In order to further assist you and to discard any hardware issue related to your SSD, we will appreciate if you can provide us with the Logs requested on our previous post. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
sunswat
Thanks for the answer.
Attach the /var/ log/messages file.
These symptoms are not continuous symptoms.
We have had 115 of 1883 trials.
I tested the write speed with dd command after booting.
I understand that this issue now appears on many sites.
JosafathB_Intel
Hello, sunswat, Thank you for your reply. As mentioned in our previous post; In order to further assist you and to discard any hardware issue related to your SSD, we will appreciate if you can provide us with the SSU logs and the SMART logs extracted from your Intel® SSD DC S4500 Series. This to have a better understanding of your PC and the SSD status. We will be looking forward to your reply including this information. Best regards, Josh B. Intel Customer Support Technician Under Contract to Intel Corporation
sunswat
Korea and the United States have a time difference and can only respond once a day.
Please request the necessary data at once.
We are using CentOS 7.
We will attach the requested contents to the attached file.
JosafathB_Intel
Hello, sunswat, Thank you for your reply. Based on the logs provided the SSDs seem to be working as expected and no SMART errors or alerts were found in our Intel® SSD DC S4500 Series hardware. In order to get further information about the environment that this SSD is been used. We will appreciate if you can provide us with the SSU logs extracted from your PC. • The SSU logs. 1- Go to https://downloadcenter.intel.com/download/26735/ and download the software. 2- When finished downloading it, open it. 3- Attach the file obtained to your reply. We will be looking forward to your reply including this information. Best regards, Josh B. Intel Customer Support Technician Under Contract to Intel Corporation
sunswat
Thank you for your help.
We are currently using CentOS 7.6.
SSU.tar does not seem to be available in this version.
Is there anything that fits this version?
sunswat
One of the two mirrored disks is now forcibly removed for testing.
Please refer to it.
JosafathB_Intel
Hello, sunswat, Thank you for your reply. Based on the Logs you shared with us the Intel® SSDs DC S4500 Series are not reporting any kind of SMART errors/alerts. In the other hand, the SSU log is not showing your SSDs as detected, this can be due to the usage of a RAID controller as your LSI*3008 and the OS compatibility. We advise you to check with the RAID controller manufacturer for updates of the firmware and compatibility. Thank you for your patience and understanding, if you have future questions, please don’t hesitate to contact us. We will be more than happy to help you in any way we can. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello, sunswat, Thank you for having contacted Intel® Memory & Storage Support. This is just a friendly reminder that your case remains open. Should you need our technical assistance please do not hesitate to contact us back. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello, sunswat, Thank you for having contacted Intel® Technical Support. I was reviewing your community post and we would like to know if you need further assistance or if we can close this case. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
