Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Intel SSD 320 80GB slow read 110 MB/s
I'm using my SSD 320 80GB since 4 month in my business HP laptop 6530b.
I was wondering that file delete, boot and opening big excel files took much longer than a few weeks ago. The laptop is running 9 hours every day
I run the benchmark tool ATTO first time and the read performance is lower than expected.
The SSD was filled with 74GB for a few days, could it be that this reduced the read performance?
newest firmware
BIOS setting is AHCI
Windows 7 - new installed on this SSD 4 month ago
the disk is encrypted
I used a Vertex 2 in this laptop and got a read performance of 250 MB/s last year. So it couldn't be a limitation of the sata controller.
Has anybody the same experience with slow read?
Community Manager
nobody with the same read performace problem?
Community Manager
It sure sounds like you need to do a secure erase and reinstall. I've heard that you need to leave about 15 to 20 percent of the drive free but there is so much misinformation on the web I didn't know what to make of it. What does the Intel Toolbox say about the drives health?
If you end up doing a secure erase please report back on your results to this forum. I for one would like to know if this solves your issue.
Community Manager
I found the reason for my performance issue: the McAfee Endpoint Encryption
I deleted the partition and installed a fresh windows 7 -> 250MB/s read performance
installed the McAfee Endpoint Encryption 5.2.3 -> read performance slows down to 110 MB/s
Disk ist 50% free
I checked the McAfee knowledge database, SSD performance is a known issue with the full disk enclyption and should be solved with the newer Versions
I don't belive that my company will invest money a new version next time, so I have to live with the slower performance
Community Manager
Although I imagine you must use your employers encryption software, the 320 SSDs have built in encryption.
